My 1996 Chevy Cavalier doesn't move. It will turn on, but when I shift it into any gear it won't move. I've check the linkage and it seems to be intacted. The transmission fluid is perfect.
SOURCE: 1996 Chevy Cavalier - How to replace the spark plug wires?
one at a time so you dont lose firing order ..which is 1 3 4 2
SOURCE: Where is the PCV Valve located on the 1996 4 cyl Cavalier?
the thumbscrew with a hose coming out on the pass. side of your valve cover
SOURCE: How do I check/fix my shift linkage ( 2003 cavalier )
well my vote is byest since i am a mechanic lol, but all joking aside no its not too had to adjust it. there are set screws holding it all in place on each linkage and just make small adjustments and test each time...
good luck
need more info just comment back ill grab some all data info for you.
