Computers & Internet Logo
Posted on Oct 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I formated my computer....a asus p4b 1.5 mhg....turn it on and off while re-installing all of my software. once done i turned the puter off to clean the cpu fan... since the puter would not turn itself back on, i tried a couple of time and nothing...except a loud alarm going off after about ten seconds of power.....help
Anonymous
Level 2:
Scholar:
  • Expert 94 Answers
  • Posted on Oct 18, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
94
Questions
0
Helped
18945
Points
255
Hi hope this helps.
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
A
Anonymous
Thanks...it was the cpu that was overheating and burnt....i appreciate your help
Cannot find acpi\atk0110 driver to download.
Hello the download site is here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=15&m=P4B-M&os=17&hashedid=n%2fa
Please select your windows system.
The driver is probably a part of the intel software utility.
Try to download and install this:
Intel(R) Chipset Software Installation Utility V5.02.1003.
In Utilities you can find it.
Click on global for download and unzip the file before you install it.
If this not helps you download it here:
http://vip.asus.com/forum/view.aspx?id=20090914095814765&board_id=1&model=M3N72-D&page=1&SLanguage=en-us
You may have to reboot after the installation is done.
Good luck
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Asus p4b user gude
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Could not detect HDD on my Asus P4B-M Motherboard
hi,
try removing with jumper behind the hard disk. and the see the cable or plugged in properly and do automatic detection of Hard drives in Bios
Want to replace noisy fan for ASUS Intel 845 Chipset P4B Motherbo
This should give you time to find a new fan
Remove paper center from fan and put a small drop (I mean small) of light machine oil on the bearing then replace paper center.
This should get you out of trouble for a few months at least.
I have done this with at least 8 fans in the past some never needed a new fan
Usb hdd is not recognized i have 2 usb ports in the back if i switch mouse to 2nd port will not work if I set the hdd on 1 port it says it has a usb device but does not recognize it
if you are runninf windows xp than do an update to service pack 2. that should fix the usb problem..... you can do that by going to www.microsoft.com and clicking on the service pack 3 option than you will need to install the update software whitch only take about a min. than press express and the software will scan your computer for the latest updates. you might need to do this 2 times if ou are running with service pack 1.
Sound problem
First of all when you installed the sound card and turned on your pc did your operating system detect the sound card. If it did then you would need to install the software driver. In some cases the operating system will have it built it and configure it on its own. If you installed the software and it you still got no sound, Go to device manager and find the sound card. If its there, right click and update driver. If is still does not do it then right click and remove driver. Restart your computer and it should detect your card and then reinstall software. now if it still does not work or detect your card then possibility bad sound card. Hope thats helpfull to you.
2answers
Motherboard
normally if the monitor is not working after switchin on the computer its the memory card remove the memory card and insert it rightly or some time with graphics card if bult in reset ur bios
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
