The ipad2 is fine when in th same room as the router, but as soon as i go upstairs it loses wifi
Sounds like the Ipad is getting out of "readable" range of the WiFi signal. You might log into the router and change the channel to channel 1. If that does not work, try another channel. If no channels work, you will probably need a Wifi extender to get the signal upstairs and readable for the Ipad.
default password is password
Looking for the NETGEAR WNR1000 default password?
You probably have little reason to access your router on a regular basis so don't feel too bad
f you've forgotten the WNR1000 default password.
However, when you're troubleshooting a network problem and need to get in to the device,
the WNR1000 default password suddenly becomes very important.
For most versions of the NETGEAR WNR1000, the default password is password. As with most passwords,
the WNR1000 default password is case sensitive
Be sure to change the default router password on your WNR1000 to something more secure as soon as you're in.
Then use a free password manager so you'll never forget your new WNR1000 password
hope this helps
hope this helps
