I have a simialr problem. It is an american standard single handle faucet. There is no separate sprayer but you can pull the faucet out and use it as a sprayer. I have replaced the cartrige and that didn't solve it. THe leak is around the base of the faucet "tower". As much as i try, i can't seem to remove the tower. It will pull up about a centermeter and then get stuck. No about of wiggling and pulling will get it past this point. I don't want to undo the locking nut under the sink as unfortunately the genius who installed it put it in in such a way as it sits flush with part of the counter. I'd have to take most of the counter apart to get it undone or maybe remove the sink.I have a simialr problem. It is an american standard single handle faucet. There is no separate sprayer but you can pull the faucet out and use it as a sprayer. I have replaced the cartrige and that didn't solve it. THe leak is around the base of the faucet "tower". As much as i try, i can't seem to remove the tower. It will pull up about a centermeter and then get stuck. No about of wiggling and pulling will get it past this point. I don't want to undo the locking nut under the sink as unfortunately the genius who installed it put it in in such a way as it sits flush with part of the counter. I'd have to take most of the counter apart to get it undone or maybe remove the sink.
I have the exact same problem as the previous poster. Can someone please come back to this issue with a resolution?I have the exact same problem as the previous poster. Can someone please come back to this issue with a resolution?
AnonymousDec 17, 2008
I wish I knew how to remove this faucet. Has anyone achieved this removal?I wish I knew how to remove this faucet. Has anyone achieved this removal?
I have a delta single handle kitchen faucet. I took the handle and top off and, by all accounts the spout should simply lift off. I have wiggled and tugged and worked it to death and it only comes up about a quarter of an inch and then is stuck there. It won't come off. I would like to replace the o rings there but have no idea what to try next. Something is holding it from coming off. Any ideas? I have a delta single handle kitchen faucet. I took the handle and top off and, by all accounts the spout should simply lift off. I have wiggled and tugged and worked it to death and it only comes up about a quarter of an inch and then is stuck there. It won't come off. I would like to replace the o rings there but have no idea what to try next. Something is holding it from coming off. Any ideas?
I have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do I remove it and replace the washers? I have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do I remove it and replace the washers?
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
I had the same problem and found that the connection where the hose connects to the pull-out faucet had come loose. Pull the faucet and hose out some and tighten. The water had been leaking back down the shaft and coming out the base.
I checked online at www.plumbingwarehouse.com/american-standard-kitchen-faucet-hamilton-4040. There is a diagram that shows a seal kit that probably needs to be replaced. The diagram is really good and shows a complete breakdown of your faucet. I hope this helps.
Hi! If there are no leaks from around the spout, you can remove the spout and apply silicone lube to the spout o-rings and resemble. If it is still hard to move ,replace the o-rings.
The base of spout is like a nut unscrew then lift off spout install new o-rings be sure to use plumbers grease or vaseline to coat new o-ring ,reinstall as was disassembled that should take care of problem.You may need a strap wrench to remove spout base nut.
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
How long have you had this? is everythign tight? check underneath the sink to ensure all connections are tight. The spout may have came loose, and it may not be able to be fixed, may need to be replaced.
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
the water comes out from the middle piece at the base.
