Always sounds like I need a new pair of headphones when I don;t.
The headphone socket in the GoGear is faulty. If you can hear sounds from both ear pieces when you wriggle the headphone plug in the GoGear, then the headphone socket in the GoGear is faulty. This fault can be easily fixed by removing the circuit board in the GoGear and resoldering the headphone socket to the circuit. You need a very fine tipped temperature soldering iron to do this job.
SOURCE: NO sound??
Make sure the volume is turned up sufficiently. If it is, then get it exchanged if still in warranty.
SOURCE: NO sound??
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab. Then click on the “Repair” button to start the repair process. Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in. If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
