Video Cameras Logo
Anonymous Posted on Jan 18, 2012
Need a driver for gr-x5u video camera
I moved from an xp operating system on an old computer to Windows 7 on a new computer. The new machine, a HP Pavilionjh intel core 7 cannot recognize the video camera and after talking with HP it is determined I need to install the proper driver. I've left a message with HP customer support a couple of days ago but haven't heard anything .Anyone know where I can get this driver?
  • 1 more comment
  • Anonymous Jan 20, 2012
    The computer recognizes the dvc to the extent when I set it to photos the computer will recognize the dv card it has installed and pull the pictures off. When I switch the camera to video mode, the computer loses knowledge the camera is connected. I deon't know it there is such a thing as a "dv cable" that differs from the usb cable I'm using to connect the camera or not. I clan't use a firewire connection because this model HP Pavilion doesn't support that capability. My bad for not checkingthat out before buying.My camera supprts both usb 2 and firewire. The computer supports usb 2 and 3.
  • Peter Yang Jan 26, 2012
    You can buy a FIREWIRE or ieee 1394 PCI card and install it into your PC (if its a tower) or buy a ieee 1394 to USB cable and try using that. There are many options out there.
  • Anonymous Jan 26, 2012
    Unlike HP's initial response that all I need is a compatible driver, that is not the answer which I confirmed during a subsequent call to a different HP tech person. The problem is the motherboard in this computer can't accept an ieee 1394a fire wire card. It has nothing to do with software. It has to do with the hardware; i.e., the motherboard. I have to find a way to come out of the camera with firewire and connect that to something that will allow USB 3 input to the computer. SYBAUSA says they have a device, SY-HUB50041, that will do just that IF the motherboard has a Firewire 10-pin Header and an ATX Power Supply Molex Power Connector. I am now going to get in touch with HP Tech support to confirm or not these are present.
Peter Yang
Level 2:
New Friend:
  • Expert 74 Answers
  • Posted on Jan 18, 2012
Peter Yang
Expert
Level 2:
New Friend:
Answers
74
Questions
0
Helped
13109
Points
177
Http://support.jvc.com/consumer/product.jsp?modelId=MODL027421&pathId=26&page=1&archive=true
I think you're best option is to look for software that is compatible with your MiniDV camcorder. It seems Cyberlink was the original install software, so I would try finding or buying Cyberlink to see if it will work for your camcorder on a Win7 machine. If the link doesn't work, you might have to cut and paste twice.
I have jvc GR-D53AS mini cassette CAMCARDER and also i have software and drivers cd. but It is not work on my win 7.(worked on win xp) I want to updated version which is work on windows7. because i h
I can understand your problem. I have the same problem with Windows 7 software for a video capture card manufactured by Canopus (Grass Valley) After much searching and experimenting I decided that the best solution was to maintain a Windows XP machine for this one purpose. In my case it was a cheap solution because I have a collection of Windows machines that I can use. It enabled me to capture my old family movies on DV tape format and then transfer them to my newer machine for editing. Sorry I don't have a better solution, but sometimes technology progresses faster than is convenient for some of us.
Cheers, Don.
Hi, my CD/DVD ROM for compaq D510 SFF is only able to read "set-up" files(I mean the ones with an 'exe' extension), but it can not read or play music/video Disks..I previously loaded Win XP but now I...
Oh mind you that other computers or systems are only designed for Windows XP and the Drivers that are installed on that machine are XP compartible. Now that you are using windows 7, it could be an issue that Windows 7 operating system does not recognize the device being your CD drive.. You need to go on the HP official website and look for the drivers (the whole packge ) for your computer model and check if Windows 7 operating system is compartible with the machine. Otherwise the solution is to go back to Windows XP...
JVC gr-d396u camcorder; need driver installed (tried with xp and windows 7; camcorder too old? 2006-2007 model); computer is recognizing firewire and usb cords, but not the camera; camcorder works fine...
Glad to help YOU!
I think all you need is a SOFTWARE called DriverWhiz.
It can be found HERE.
Click on RUN (or SAVE AS - if you use Firefox) and let it be installed on you machine. By using this DriverWhiz you will be able to:
# find missing drivers for any JVC device
# update the existing drivers
# backup your existing JVC drivers
GOOD LUCK!
6helpful
Driver for dcr hc 62e
Windows 7
* Drivers:
o The drivers needed to connect your Sony camcorder to a computer and transfer files are already included in the operating system.
* Not Supported:
o The USB streaming feature is not supported with the Windows 7 operating system.
o The Windows 7 Starter edition is not supported.
Windows Vista
* Drivers:
* Not Supported:
o The USB streaming feature is not supported with the Windows Vista operating system.
o The Windows Vista Starter edition is not supported.
* View Detailed Windows Vista compatibility information.
Windows XP
* Drivers:
* Not Supported:
o The Microsoft Windows XP 64-bit operating system is not supported.
o The Windows XP Starter edition is not supported.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2answers
I upgraded the Operating System of my computer from Windows XP to Window 7. My problem is the installer or driver of my printer,HP Deskjet D1300 is not compatible for the new windows. What should I do in...
Sorry, there is nothing you can do, this printer is so old that HP never bothered to make even a Vista driver for it, let alone a 7 one.
If you can install XPMode in your 7 then you could install and use this printer only in there, otherwise you will need a new one.
1helpful
2answers
Is a driver available for a JVC GR-D40 cam corder that is compatible with windows 7
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
1helpful
I search driver for windows 7 for my JVC camera GR-DX35E thank's
julyallan01_12.jpgMaybe, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatiblity". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D
2answers
Where can i find the driver for JVC GR DVF 31? when i connect the camera to the usb i get the error saying usb not recognised what can i do?? im running windows 7 i no its an old camera but i really need...
i had that happen with my laptop and my hp printer take the chords out of the machines,blow them off and sit them down for 1 day then blow them off and try again!!!
My computer does not see my JVC GR-D770 connected by a DV cable. I am running windows 7. What can I do to download the video?
USB connections on cameras wont work, no drivers are in windows since XP, just grab a Fire Wire cable (No driver needed) and away you go.
byee
David
Need xp drivers for JVC GR-D70U cam corder
I had a similar issue. I had never been able to download video to computer because the computer never recognized the camera. As a last resort, I bought a new firewire cord today -- and my computer recognized the camera as soon as I turned the camera to play! It was four years in the making (I thought there was something wrong with my camera this entire time!), but it was just a cord issue. Now the cord that came with the camera is in the trash, and I can download video. I did buy an (XP) driver for I think $8 online, but I'm not sure whether that really had anything to do with it (I have SP3). I bought it from www.helpdrivers.com, and it was called the JVC / GR-D70U USB Mass Storage Class Driver + G.726 Decoder / Windows 98-98Se-Me-2000-XP, Item# 3021598. Downloaded it from the site. Hope that helps!
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
