Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
Kirby Series Owner Manual
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
SOURCE: Kirby Generation 3 manuals
No, the manual is not available online, but I have users manuals for sale in my store. My store is located on a POPULAR auction site under the same ID as I am using here on this blogsite. Marci
SOURCE: Manual
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=617575
Manual
Posted by Caroyl on May 23, 2008
Is there a manual I can download online for the
Kirby Ultimate G Series Diamond Edition, Model G7D?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My suggestion is that you contact the Kirby Co in Cleveland listed below and they will instruct you either to down load a owner’s manual or they will mail one out to you, there might be a local Kirby dealer in your area that might have a manual as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
SOURCE: smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
