Mitsubishi WD-57733 57" HDTV Logo
Jim Billings Posted on Jan 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi green blinking light of death
Got the green blinking light of death. Won't power up. I read I have to replace a couple of caps on the dm board
Anonymous
Level 3:
  • Mitsubishi Master 2,098 Answers
  • Posted on Jan 11, 2012
Anonymous
Mitsubishi Master
Level 3:
Answers
2098
Questions
Helped
456546
Points
6457
Hi Jim,
Green blinking light of death on Mitsubishi DLP TV means that the DM failed to booted up. I would advice you to replaced the 7 1000uf electrolytic capacitor on the DM board. Most of the time it fixed the symptoms. Please inquire at tvrepairworld.com if they have an available DM repair kit for V36 chassis (WD-57733 chassis).
Jdvillanueva
Testimonial: "Thanks, I just ordered 10 of the caps online. I work as an electronics tech on an army base. I'll pull the board and fix it at lunch. Thanks for your response. It will save me some time. Jim"
Ed Arnold
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 04, 2014
Ed Arnold
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1707
Points
I went online and ordered 20 caps for $3 which included shipping. Had up and running in about 2 hours. I have extensive auto repair experience but not so much in circuit board repair. All in all it's a simple repair.
5 Related Answers
Anonymous
  • Posted on Nov 21, 2008
SOURCE: mitsubishi tv repair WS55859
same problem I am having....tech came out said it was probably the board containing the power source which on my tv is the right circuit board, said he would either have to buy complete board or get a refurbished one....probably about $400 bucks.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jun 03, 2008
SOURCE: green blinking light problem too. on a Mitsubishi WS65869
You can go to this link they have the kits with the high temp higher volt capacitors and complete detailed instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Anonymous
  • Posted on Feb 06, 2009
SOURCE: Mitsubishi blinking green light of death
I just replaced the 4 caps on my WS-65513. I had some trouble w/ getting the board back in (and out for that matter). I took my board to a local repair shop and had them do the soldering. But when I got if back I had some trouble getting the board to line up right, it would work sometime then go back to the blinking. So you might try adjusting the board to make sure that it's lined up properly in the slots. Mine looked like they were, but every time i'd put the screws in the hold it down it would move the board maybe a 1mm and it wouldn't work.
Rocky Beech
  • 4 Answers
  • Posted on Feb 18, 2010
SOURCE: wd62825 blinking green light
I am also a member of the WD-62725 blinking green light club. I replaced all twelve of the caps I found with higher rated ones and the blinking light problem did not go away completely but I could get the TV synced in 5 or less cycles...for a while. I finally put the TV on an UPS and it did pretty good for about a year until, for some reason, my wife muting the TV would send it into a blue screen and then the dreaded blinking green light of death. I had collected a lot of forum notes and bought the manual (virtually useless) and remembered a post where a guy put a switch on the orange power wire going to the "board to the right of the DM board," as he described it. This was the last attempt for me so I tried it. The board's name is the FMT PWB and on his WD-62825 and my WD-62725 it is the right most board, looking from the rear. Coming off of the top of the board towards the back of the set is a 4 wire connector with one of the wires being orange. Cut that wire and splice 12" long extensions to each leg. Reassemble the TV with these two new wires hanging out the back. Solder an on off switch to these leads. I used and old PC power switch because it had large "On" and "Off" labels on it. I then screwed it to a hole in back with a 1" stand off. Its not pretty but functional. Now turn your new switch off and plug the set in. If it behaves like mine it will blink green for about a minute and then go off. Now turn the new switch to the on position and you are ready to turn on your set. I hope this helps. If it does give me some feedback at rocky_beech(at)yahoo.com. I only need mine to last two more years and my house will be paid for and then I will get the best I can afford. I hope they still have plasmas by then. Cheers
Anonymous
  • 3 Answers
  • Posted on Oct 01, 2010
SOURCE: I have a mitsubishi ws
Age of unit: About 7 years.
Rear Projection HD set, Mitsubishi WS-55511
Nature of problem: Blinking green light of death. Upon plugging the set back in after vacation, the green LED on the front of the set would blink continuously and the set would not turn on. I ordered the blinking green light kit from tvrepairkits.com after seeing this link on a tech forum, suggesting the capacitors were bad on the DM board inside the DM module. The kit arrived within days of ordering. The online instuctions were very detailed and could be followed even by a layman such as myself. Very detailed with lots of photos. My DM module was simpler to remove than the instructions indicated. It simply slid out after about five cables were disconnected from other boards. The module itself is the silver box all the way to the left when looking into the rear of the TV (from the rear of course). There is a plastic guard that surround all the input connections (coaxial connections, home theater control inputs, etc). This is removed with 3 screws. After all the cables to this module are unplugged from other circuit boards, the module will slide out towards you. Then you take the cover off (including the clamp where all the cables are routed into the module) and you can see the DM board (it is labled as such and has 7 capacitors. None of the capacitors were bulged or otherwise defective looking as other posters have reported. Changed them all anyway. Buckled everything up and plugged the set back in. The blinking light started as it always had. It should normally go out in about a minute after plugging in to wall. I really didn't hold out a lot of hope that it would go out....and then....it went out! I pushed the power button and she fired right up! What a thrill! Including shipping, it cost me $45.90 to fix a set I paid about 3000 bucks for 7 years ago and was loathe to just throw away. I certainly wasn't going to pay nearly a thousand bucks to fix this set. It may be a little bulky, but the picture is beautiful as well as the sound system. You guys are great. A very reasonably priced gamble that worked. Watching a movie in HD while I type this, good to have my TV back after almost two weeks without it. I actually can't believe I did it!
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
