My double oven seems to have part of it not working, but part still does. None of the display lights work. The sounds still work. The oven light itself works. The circuit breaker has been flipped a few times with no results. The oven will not heat up either. The manual says nothing about this problem so I'm guessing some board may be blown and I'd like to fix it, but need to figure out what part to order. Any clues?
SOURCE: Whirlpool Double Oven GBD307
there are three possible issues, one is a faulty ground. the computer uses ground to determine zero in binary logic. It could also be a stuck key on the input board, or the main control board. Check your owners manual, some units come with an exceptional warranty on the electronics. This is a big one and it may be worth your time to call a tech in to check it out. electronics are expensive and you can not send them back if you diagnosis is wrong.
SOURCE: Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
appliance parts, help &
more
