Armitron All Sport Digital watch Logo
A
Anonymous Posted on Jan 07, 2012
Turn off alarm on armitron 45/6999 - Armitron All Sport Digital watch
4helpful
3answers
How do I turn off the alarm on Armitron 45/7042?
Hold A, and B and press C, mine shut off
How do I turn off the alarm that sounds every hour on my armitron all sport watch?
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
1helpful
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
3helpful
3answers
I can't find the user's manual for this watch: Armitron Sport 40/8125BLK Watch
You can download the user manual for your watch from this link(http://www.watchesmanuals.com/Armitron/Armitron-Sport-40-8125BLK-Watch.htm)
6helpful
Armitron WR165 How can I turn the alarm off
Assume: A C
B D
While holding A, press C. This toggles the hourly chime and alarm on/off.
2helpful
How do I cancel the alarm?
Follow this link and find instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
Mar 11, 2009 • Watches
124helpful
3answers
Ladies Armitron 45/6967
Armitron alarm/chrono
1.To set the time hold the mode button until the alarm flashes, then hit it one more time and the time will flash to be changed. Once the alram or time is flashing use the ST/STP button to navigate between hour, minute, month, day and day of the week, the ADJ button changes the numbers.
2.While holding down the ADJ button use the ST/STP button to turn off the hourly CHIME and the ALARM chime.
Hope this helps!! K~~
5helpful
How to set armitron digital watch 45/6915?
Assume A B
C D
To turn off the alarm press & hold A then press B, do this several times until your alarm/chime is either on or off.
Top Armitron Watches Experts
Gene Lawson
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Armitron Watch Expert? Answer questions, earn points and help others
