SOURCE: Trying to hook up ipod thru receiver to Sony TV???
here is the link to Apple's site that will show you what iPod A/V cable you will need to buy that will allow you to send audio and video to your television. Heres the link.
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
SOURCE: can't get audio from HD TV to run through Yamaha receiver speaker
be more specific!...how is the tv hooked up? hdmi, component, straight to the tv, or into the amp then tv?....what audio out? optical, digital? also what are you trying to view? local programming? cable/sat? dvd? your best bet is to ignore video on the amp and go straight to tv. can't help u more until i have more specifics.
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
I also had this problem. you need to call Yamaha Tech Support (in your country) and explain to the consultant that you need to set up your receiver to decode the Audio from the HDMI input (so it will play the sound from the HDMI cable). Yamaha Australia said that this function is not described in the book and also said its a stupid mistake on Yamaha's Manual. So just give them a call and they will fix it for you. It WORKED for me :D
