Error Message: Error 003 Unauthorized Device Has Been Detected
Situation:
Information:
This error code indicates the region the system was manufactured for is not compatible with the Wii System Menu update. This incompatibility has made the system unplayable and it cannot be repaired. Nintendo is not able to provide support for these systems.
function rvl_ts_sys_error_003_showsurvey(){
omnitureHelp("helpful_survey:rvl_ts_sys_error_003",JSchannel,JSprop6,"","");
var req;
var timeout;
function rvl_ts_sys_error_003_psurv(a,sid,pid){
if (window.XMLHttpRequest)req = new XMLHttpRequest();
else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP");
if(a=="yes"){
document.getElementById("rvl_ts_sys_error_003_s_yes_button").innerHTML="";
document.getElementById("rvl_ts_sys_error_003_s_no_button").innerHTML="";
else{
var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid;
req.open("GET", url, true);
timeout = setTimeout("techDif()", 5000);
req.onreadystatechange = rvl_ts_sys_error_003_psurvr;
req.send(null)
function rvl_ts_sys_error_003_psurvr(){
if (req.readyState == 4) {
if (req.status == 200) {
clearTimeout(timeout);
var outString=req.responseText.substr(req.responseText.indexOf("##")+2);
outString=outString.substring(0,outString.indexOf("##"));
document.cookie='rvl_ts_sys_error_003=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/';
document.getElementById("rvl_ts_sys_error_003_s_folowup_div").innerHTML=outString;
function rvl_ts_sys_error_003_techDif(){
//it broke
document.getElementById("rvl_ts_sys_error_003_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us.";
function rvl_ts_sys_error_003_clearboxsurv(whatto,box){
if(box.value==whatto)box.value="";
function rvl_ts_sys_error_003_fsurv(form){
var url="/consumer/surveys/surveySubmit.jsp?p=7"
var reasonSet = false;
for(var i=0;i-1)reasonSet=true;
}else if(form.elements[i].name.indexOf("question2_answer")>-1){
url+="&"+form.elements[i].name+"="+escape(form.elements[i].value);
}else url+="&"+form.elements[i].name+"="+form.elements[i].value;
if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;}
req.send(null)
To solve this error:
Error Code 52230 means
that your router or Internet Service
Provider is having difficulty assigning a DNS or IP address to the Wii. What this usually means when you had a connection
and it drops is that you aren't getting a clean signal connection between your
router and your console. First step,
unplug your modem and your router wait 30 seconds and plug them back in. If that doesn't work:
Various factors affect connecting a Wii to the internet with a
WiFi connection as well, including signal strength, distance from the
wireless router to the console and obstacles such as walls and ceilings that
interfere with the signal. If you're using a G router and you have your
Wii too far away or, has obstacles (walls and ceilings) in the way, it will not connect.
You should use an N-Router if there is a significant distance between the
console and the router or if there are obstacles.
In your case it could be the wireless adapter on your computer is interfering with the Wii. Change your router's
channel setting to 1 or 11. By default, most routers broadcast on channel 6,
which overlaps with other channels and may be weaker.
