Apple iPhone 3GS Black (16 GB) Logo
Anonymous Posted on Dec 22, 2011
How do I delete the photo stream albumn or images in it on iphone 3gs
It seemed to be a well discussed problem but no one has come up with an answer yet? The problem is it takes up valuble space duplicating images in a different albumn
  • Anonymous Dec 22, 2011
    No camera roll is different albumn is a different albumn which doesn't have the dustbin or a delete option but I have since found that logging into Icloud and going advanced then gives you a reset photo stream option. Then turn off photo stream on your Iphone then deletes all the photos only in the photo stream folder and works!! hope this helps others struggling!
Prashant Sharma
Level 3:
Genius:
  • Apple Master 1,127 Answers
  • Posted on Dec 22, 2011
Prashant  Sharma
Apple Master
Level 3:
Genius:
Answers
1127
Questions
0
Helped
237409
Points
3825
Hi There
Its very simple to delete photo or photo stream to you iPhone 3gs
  1. Press the menu button and select photos.
  2. Select Camera Roll option and now hear you can get you all capture photo
  3. Now select which photo you want to delete, when you select the photo you saw option in you down right side like -(dustbin)
  4. Press that option now the pop up appear two option "Delete & Cancel" chose Delete option.
  5. Now you photo is delete if you want multiple select then you see in corner side "Multiple select option" select that one now you able to delete multiple photo in one time.
  6. Select which photos you want to delete.
See the video for halp
Video 1: Simple Delete
Video 2: Multiple Delete
I want to delete photos etc ond my icloud to get more space without buying more storage?
The following guide will show you how to delete unwanted photos/videos on iCloud.
1. Tap on Setting > iCloud > Storage. Then tap on Manage Storage.
2. And then tap on This iPhone.
3. Under the Backup options, you will see Photo Library option, set the slider to OFF position.
4. Tap on Turn off & Delete to delete all photos and videos from iCloud.
After deleting existing photos and videos, you can either set the Photo Library back to ON position and start backing up new photos to iCloud or keep it OFF and use Photo Stream. You can store up to 1,000 images on Photo Stream for free and download them to your computer. These images will remain in Photo Stream for 30 days, after which they will be deleted.
How to Fix Not Enough Storage on iCloud for Your iPhone iPad
Mar 25, 2017 • Cell Phones
I want to delete some videos from iCloud How can I do this on my iPad 2?
  2. And then tap on This iPad.
Why cant I get picture messages on my phone
All iPhones have the capability of sending and receiving MMS (photo) messages. This is a carrier related limitation. Call your carrier to discuss how much this option costs.
How to delete photo albums on iphone 3gs
Have you tried deleting them one by one? Also try connecting your phone to itunes you may be able to remove them that way.
Mar 11, 2013 • Cell Phones
1helpful
Can I install android under iphone 3GS with new iboot ?
Don't listen to most of people who answer questions like yours. If you call apple and start talking about iboot or any other jailbroken iphone stuff they're just gonna laugh at you. From what I've heard is that android only works on edge iphones. I dont really know if that means that it only applies to the 2g silver backed iphones or not but I know my 3gs is able to use edge. I've not seen android make a cellular call either while on the iphone however skype seemed to work. I would try it if I were you though. The modified android download can be found floating somewhere out there on the web. Also as far as I know at this time its in beta. Not all features are supported.
Iphone photos
opened iphoto and it gives "no items to import" ? if true try this. when iPhoto is open and your phone is connected, open the albumn of pictures you've taken with your iphone on your iphone. iPhoto should immediately recognize the new pictures you had taken and should indicate "x items to import." x being number of photos. An alternative to this can be If you individually delete the previously imported iPhone Camera Roll pictures using the trash can on the bottom right (touching the screen brings it up), iPhoto will then see the new iPhone pictures for importing. I believe this can be done without opening at the time of sync the iPhone Camera Roll picture album as you suggested. Give these a try and let me know.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
