Have a new bt modem router although my acer travelmate says wireless network is connected to the internet signal strength exellent the acer will not connect to any website -internet explorer cannot display the webpage. dianostic says cannot find the wireless network you are trying to connect to
SOURCE: Wireless connected but internet not working.
try opening ie then clicking the file tab, look to see if there is a tick next to 'work offline' if there is then uncheck it.
SOURCE: Acer Aspire 5570-2609, Windows Vista
Welcome to Fixya
Since the computer was able to detect the wireless router, there should be no problem connecting to the internet. Please go to the computer command prompt by clicking start menu then type in to the start search bar CMD then press enter. Type at the command box ipconfig /all .
Please reply to this email reagarding all the details you will see when you do the ipconfig /all.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: I have an acer aspire one laptop that will not
1.- Try to find the wireless card switch (or button). Look the wireless led indicator, must be on.
You should surf if the led is on.
2.- If not works, go to device manager and look to your wireless device and turn the switch on and
off again. Look if the device is accepted without any sign. If the device get any sign then you
have problem with your wireless driver. If no sign. Open My Computer and then open networks
or my network places, and try to access to any other computer you have.
3.- If the device is ok in device manager and the led indicator is on and you can access other
computer thru network places, then open Internet explorer, go to tools, then go to internet
options, then go to connections and there click on Lan settings. In the proxy section uncheck
the box. Restart your Internet Explorer and it must surf now.
Good Luck and remember to rate my answer.
SOURCE: I recently replaced my old
Remove and recreate the wireless network connection
In Windows, there is a power mode setting for the wireless driver that may help this issue. Follow the instructions below.
Check to see if this has resolved the connectivity issue. If it has not, the following steps may need to be completed.
The default setting is Maximum, which may cause issues similar to those described.
