SOURCE: H01 Error
H01 means that there is an alignment problem or there's a faulty lens mechanism. Align it would cost about $50 . If there is a faulty part , then cost would start from about $80 labour plus part.
Testimonial: "Thanks so much...repair is probably not worth the cost...."
SOURCE: Error code H01
it means no head motor rotation...The full meaning is given as: After Cylinder lock is detected the cylinder does not start rotating again even after tape unloading.
The remedy/ check is given as: Check the cylinder motor drive circuit... sorry no solution but at least you know whats wrong..
H01
Pressure sensor or level switch detected as out of range
