Apple iPhone 3G Logo
john burns Posted on Dec 08, 2011
I want to download photographs from my iphone?
How do I download my photos
Oscar Russell
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 26, 2016
Oscar Russell
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
121
Points
You want to download iPhone photos to your computer, right?
If you're a Mac user, then you can simply use a program named Photos on your Mac. Photos is the latest app released by Apple that has replaced its earlier iPhoto program. Though the basic features and functioning of Photos is similar like iPhoto, there are a few improvement and changes so as to enhance your overall experience.
  1. Connect your iPhone to your Mac with a USB cable. You might need to unlock your iOS device using your passcode. You might also see a prompt on the iOS device asking you to Trust This Computer. Tap Trust to continue.
  2. On your Mac, the Photos app automatically opens. If it doesn't, open the Photos app.
  3. The Photos app shows an Import screen with all the photos and videos that are on your connected device. If the Import screen doesn't automatically appear, click the Import tab at the top of the Photos app, or click the device's name in the Photos sidebar.
  4. To import a selection of photos, click the ones you want, then click Import Selected. To import all new photos, click Import All New Photos.
  5. When the import is complete, a message box asks if you want to delete or keep the photos on your device. Click Delete Items to remove the photos, or click Keep Items to keep them on the device. If you select Keep Items, you'll have to delete them directly from your device when you want to remove them.
Note: Both of the tools can only import photos from Camera Roll/All Photos, photos and videos that you sync from your computer to your iOS device using iTunes can't be imported back to your Mac computer. Therefore, in order to transfer these photos from iPhone to Mac, using third-party software proves to be an ideal solution.
http://www.leawo.org/tutorial/how-to-import-photos-from-iphone-to-iphoto.html
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 44 Answers
  • Posted on Dec 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
44
Questions
0
Helped
4715
Points
47
Plug in your iPhone to your computer, if it's a PC you will need to use the Photo Import Wizard and if it's a Mac you will need to open iPhoto.
tip
Recover Deleted Photos From iPhone 6
It can be most aggravating when an important photograph is accidentally deleted. If you have an iPhone 6, then thankfully, there are a few options available for flv files recovery from this device. Remember, it is good practice to back-up your photographs every now and again by saving them onto an external storage device.
One of the first things to do in trying to retrieve deleted photos from an iPhone 6, is to open the Photos app on your smartphone. Once you have done that, do the following steps:
1.Select the "Albums" menu.
2.Select the album that you need and then select "Recently Deleted."
3.A list of all the recently deleted photos will appear.
4.Select the ones that you want and then tap on the "Recover" button to recover all the photographs that you selected.
5.All restored photographs will be sent to the album in which they were originally located.
If the photographs that were deleted were backed up in iTunes or iCloud, they can also be recovered. The important thing to remember is to have either iCloud or iTunes backup turned on at all times. If you are unsure how to do so, here's how:
1.Go to the "Settings" menu then select "iCloud."
2.Under "iCloud", select "Storage and Backup."
3.Then turn on the "iCloud Backup" feature on your iPhone 6.
4.As long as your iCloud backup is up-to-date, then all your photos can be easily restored to your iPhone 6 in case of accidental deletion.
Backing up your photographs to iTunes is equally as easy as backing them up to iCloud. However, once you connect your iPhone 6 to your computer or iPad, you need to ensure that iCloud is turned off; you can back-up to one or the other but not both apps at the same time.
If your photos have been deleted, then recovering your duplicate photos from iTunes backup or iCloud backup is not a problem. Simply launch iCloud or iTunes, right click on iPhone (the device in question), select "Summary", and then select either "Restore from iCloud Backup or "Restore from iTunes Backup." Once that is done, wait for "Restore in Progress" to complete and your device restarted.
When all else fails, a reliable data recovery software can be used to recover deleted photos from an iPhone 6. uFlysoft is one such user-friendly software that gets the job done quickly and thoroughly. The process is simple and takes these easy steps:
1.First, connect your iPhone 6 to your Mac computer then launch the uFlysoft data recovery software. You never want to launch a data recovery software directly from the smartphone from which you are trying to recover lost or deleted data.
2.Select the "Recover from iOS Device" option.
3.The software will then scan your device and present all the recovered photographs for you to preview.
4.The recovered photos can then be saved to any storage device or the computer itself.
RE: http://www.uflysoft.com/
4answers
2answers
I need to download my camera app for my iPad.
if your iPad is not the first generation and has a camera built in, then the camera app cannot be deleted as it belongs to one of the core apps of the iOS system.
I think it was only moved to a folder and cannot be seen now anymore.....- so check with spotlight where this app is hidden.
http://www.imore.com/how-to-access-use-spotlight-seach-iphone-ipad
IPhoto sync with Mountain Lion for Mac
This is very easy and can be done two ways.
1. Connect your iPhone to your computer and sync the photos:
iTunes Syncing photos
how do transfer photos from my iPhone to my iMac
2. You can configure both your iphone and computer to sync the photos over iCloud.
iCloud Set up My Photo Stream
Apple United Kingdom iCloud All your content on all your devices
4helpful
How do erase pictures on BUMP history ?
You can right-swipe on anything you sent or received to remove it from your history. -dave
1helpful
Looking for an application that would change normal photos to an old picture into an authentic old world feel looks.
I know exactly what you are looking for. The name of the app is Oldbooth.There are stacks of male and female bodies to choose from and you can resize, rotate and even adjust the brightness of your photo to match. Once done, just fit your profile photo into the mask and you have a brand new, old world photograph of yourself. You can download Oldbooth from the Apple App Store for $1.99.
Sep 06, 2010 • iPhone Apps
2helpful
6answers
Transfer photos to laptop
You need to install itunes on your laptop so your iphone can sync with itunes and your computer.. this is used to tranfer music to your iphone, transfer photo's and video etc and also to check for new firmware versions/back up your phone.
You can however take photo's from your iphone without itunes if you connect your phone via usb and choose open folder to view files when the dialog pops up after you plug it in.. this has very limited use however you really need to install itunes. Itunes is a free download
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
