Dell Inspiron 1720 Notebook Logo
sean mcdonald Posted on Dec 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ISATAP#17 not running - Dell Inspiron 1720 Notebook
hims Patel
Level 2:
Scholar:
  • Expert 102 Answers
  • Posted on Jan 22, 2012
hims Patel
Expert
Level 2:
Scholar:
Answers
102
Questions
Helped
13505
Points
303
You have not described you problem in full detail but even i try to solve it. when laptop is in off condition you have to press R + Turn ON button which makes reset (not restore) your C MOS memory so whatever settings has been changed are automatically resets and your laptop will turns ON so just do it. If further problem occurs then immediately call DELL onsite service.
thank you for giving me this opportunity to solve you problem.
I can install the isatap adapter in safe mode but when I restart the adapter has a yellow triangle ?
It means it is not succeed, probably it is not compatible, or it needs special settings.
Need new download of ISATAP drivers
Greetings,
On a Windows Vista-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager.
You can safely ignore this error message. This error message does not indicate a problem with the adapter. The adapter will continue to work correctly.
Check out this article for more information on this:
http://support.microsoft.com/kb/932520
If this is still not working,
First try to reset Winsock from command prompt, this will reset all the Network components to default:
Click on start, type CMD,'Right click and Run as Administrator'.
At the command prompt type:
netsh winsock reset catalog
In such a case, I suspect this problem to be caused by network adapter missing or corrupt. Please firstly reinstall the driver for your wireless network adapter. Then try to reinstall Microsoft ISATAP using following steps:
1.In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
2.Still in Device Manager, click Action and select Add legacy hardware.
3.Click Next, and select Install the hardware that I manually select from a list (Advanced), click Next.
4.Select Network Adapters and click Next.
5.Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
6.Click Next and finish the remaining wizard.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution, your response will be appreciated.
Thank you and Kind Regards
Gowtam R
FIXYA Solutions Engineer.
1helpful
Microsoft ISATAP Adapter This device is not working properly because Windows cannot load the drivers required for this device.
ISATAP is Microsoft trying to allow IPv6 to function over an IPv4 infrastructure, however, it was released extremely prematurely, and as a result, doesn't like to work, or install. According to Microsoft, your computer should continue to function without ISATAP functioning,and the error message may be ignored. However, if you believe that this may be causing you some problems, then you may navigate to the device manager ( Start > Control Panel > Hardware and Sound > Device Manager ) from this window, see if you can find ISATAP adapter and 4TO6 adapter, right-click these, and select "Disable" NOTE: this may cause Internet Explorer and Windows Mail to run slower and have a few errors.
I hope this helps!
Isatap
Ivon
ISATAP is a virtual device for transfering packets.
Somehow this must have gotten corrupted, Try uninstalling your network card. Once thats done scroll up to the top of device manager and right click on Computer and choose "scan for changes"
this should reinstall your network card and with it your ISATAP protocols. This should fix your problem. I've had to do this acouple of times myself (Quite common in Vista)
Hope this helps ya
Dave
1helpful
ISATAP adaptor
you have ipv6 enabled, this is to help the worldwide convergence to ipv6 form ipv4 . were running out of addresses if not already have ran out.
so from what i can tell it works with the tunneling adapter. altho it is still doing stuff on your computer, it's needed to make the internet work right now, if anyone of you have a "microsoft wi-fi miniport adapter" all of a sudden and you also don't like that you can't get rid of it unless you go to the web and download the old driver.
neither the miniport or the isatap adapter are actually "needed" you can get by without isatap if you either disable or uninstall ipv6. virtual wifi isn't needed, but it's uber cool cause it's for your wireless card and if you connect wireless to the internet, it will let you wirelessly share out that connection wirelessly , (like your a wireless router)
i think i should not that "eventually" you will need to install ipv6 to browse the internet.
more importantly it actually isn't designed to be a "TAP" but it certainly could be the target of hackers in the future including the mini-port (only because they are both new)
http://www.istartedsomething.com/20090516/windows-7-native-virtual-wifi-technology-microsoft-research/
http://en.wikipedia.org/wiki/ISATAP
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
