I have connected the swa-4000 to my ht-z325 and it is paired up with green light remaining solid,but i still get no sound i have tried the re-set 0-1-3-5- but no joy can anyone help thankyou
SOURCE: Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
SOURCE: SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
hi...im not sure how it happened...what i did was i pressed 0135, the main unit lit up and i pressed the id set or something like that on the back of the wireless reciever.....well the main unit should be back to red and once i pressed the id set i accidentaly pressed the power button so the main unit turned on...then i waited for the wireless reciver to boot up and worked.....
SOURCE: problem with wireless conection between Samsung SWA-4000 and Samsung home theatre.
turn the main dvd player off, and press 0,1,3,5 on your remote, then turn on the player and the rear wireless receiver at as close to the same time as you can. should then light up the blue "link" light permanently.
SOURCE: i'm having problems getting my swa-4000 system to
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
SOURCE: just connected the SWA-4000 wireless
Actually the SWA-4000 IS compatible with the htz-310t. I'm using the htz-310 system with an SWA-4000 and it works perfectly fine. under the list of compatible systems with the SWA-4000 you'll see the htz-310. so i don't know where the other answerer is getting his facts.
once you press the nubmers on the remote, 0, 1, 3 5 or whatever the numbers are. turn the system on with the on button on the system not of the remote.
if the blue led is on on the swa-4000 then it's communication, there's a link.
if you do a sound test it will not send the static to the rear speakers, at least it doesn't for me. however there IS sound ouf of those speakers. so i know they work.
