SOURCE: Can't get airconditioner to work
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If wont work then there are some safety device that work or defective. Try counting the blink of your green light so that I can convert the error code.
SOURCE: Carrier Heater/Airconditioner Model 58DRC045-GB fan
You can temporarily cut off the power, expose control board, pry off upper rear relay plastic cove, remove spring and stretch it out just a little from its original length because the relay is either getting weak or there are other problems with the board supplying the proper voltage to it... anyway, when putting the spring back on be sure the relay switch is properly aligned in the holes furthest away from the board.. This should provide at least several more months of proper operation before board needs to be replaced... Quick fix, install new board... Tech Chris w/ Absolutely Fabulous! AFSO.US
SOURCE: CENTRAL ELECTRIC HEATING SYSTEM carrier
Sorry to read about your problem, I hope this helps you out.
you may have a pilot start issue....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
SOURCE: please advise heating/cooling capacity for carrier
Hello rgar919,
It is imposible to tell you the capacity of the unit without some kind of numbers to find out what it is. They made more than one unit 25 years ago. The numbers off the compressor may help to find the size of the unit. Please try and find some sort of model or serial number, compressor number, fan motor number something that can be cross referenced.
Thank you for choosing FixYa.
