SOURCE: copying vhs to dvd
you could google for macrovision scart leads that will do the job .
of transfering the vhs tapes to dvd .
riz.
SOURCE: can the panasonic dmr-eh75v copy a vhs tape to DVD?
Yes, that's mostly what I use mine for. You actually copy your VHS to the Hard Drive, then copy from your hard drive to your blank DVD. I'm about 1/3 of my way through reformatting my VHS library (800+ tapes.)
SOURCE: panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
SOURCE: How do I connect DMR-E85H to a VHS to copy tapes?
I assume you are using a seperate vcr,you need to connect a scart lead into av1 on the vcr,then the other end into av2 on the dvd,you then select av2 as your recording channel on the dvd,to finalize if you go into the disc menu it will tell you what to do.
SOURCE: where can i find a manual for my Panasonic DMR-EZ48V recorder?
You can download the user manual for this unit from this links.
http://www.panasonic.com.au/products/details.cfm?objectID=4291
http://www.devicemanuals.com/guide/DVD/Panasonic/Panasonic-DMR-EZ48V-DVD-Operation-Manual-==TWpZMU5EWXc=.html
