Our Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. We replaced the copper tubing which delivers the water to the fridge and that didn't help. We replaced the copper tubing again with plastic tubing...no better. Any suggestions? Our tap water doesn't taste this bad. We bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. Our tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You
that didn't help. You replaced the copper tubing again with plastic
tubing...no better. Any suggestions? Your tap water doesn't taste this
bad.You bought a Kenmore french door fridge with water dispenser in the
bad water taste I have ever tasted. And your tap water is fine. The bad
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Purchased a new Kenmore Elite refrigerator with a water dispenser. At first, the water and ice tasted fine. After a month, both the water and ice had a funny taste and smelled. Despite throwing away a few loads of ice and running the water, the problem keeps coming back. Could it be the new supply line that was installed. I noticed that the installer did not do anything but remove the line and install it without cleaning it in any manner. Would a new supply line eliminate the problem?
I tried two new filters and both have the same bad taste
