LG 42LH40 LCD TV Logo
Jojo Poon Posted on Oct 25, 2011
LG LCD tv turning green - LG 42LH40 LCD TV
3 Related Answers
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Apr 24, 2008
SOURCE: blinking green light no picture for a lg lcd tv
This is usually an indication that the power supply has failed. It is also possible that there is a short or failure on another board, and the powe supply is in the protect mode.
The set would require proper troubleshooting by an experieced TV tech who knows the type of set you have.
Jerry G.
Anonymous
  • 608 Answers
  • Posted on Dec 19, 2010
SOURCE: My LG 47" LCD TV
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Chi Chu
  • 8457 Answers
  • Posted on Feb 17, 2011
SOURCE: MY LG 42" LCD TV
Tries tv unplug,replug it back like about an hour later for the tv resetting itself back to the factory setting.Tries again,tv should be working.If still getting no power at all than the tv Tuner board is dead,because pictures freezing and dies completely is the causes so it is not power supply board problems.The tv Tuner signal board is the causes,that the board where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
LG HD TV turns green after about 15 minutes
Two possibilities. T'Con board fault, or panel itself. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Defective screen shots to LCD TVs are given. Hopes that can help you to diagonise the fault.
Mitsubishi ws-48413 will not turn on or off. The only sign of life is the green power light stays on and will only go out if I unplug the tv. The green light comes back on as soon as the tv is plugged back...
Https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
2helpful
3answers
LG 37LF65 LCD TV BLINKS 3 GREEN THEN 1 RED THEN TURNS OFF.
Here's a link to the service manual for a slightly larger LG LCD TV. Perhaps it may be of some help? The troubleshooting section appears to be the same for many models of LG TVs...
http://www.observations.biz/MANUALS/LG_LCDTV/42LF66.pdf
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
LG LCD 37'' standby problem
if you want i will buy the tv from you
37LC7D LG LCD tv turn's on but remote keys and tv side keys unresponsive.
HI,
I'll think your power supply is down.
Maybe there's still garanty on your TV.
kind regards,
Gerard
3helpful
2answers
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Red or green tint on LG LCD 32" TV
Misaligned white balance adjustment. If you wish to get some details; visit the site linked here. Pull up older posts.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
