Samsung HT-TQ85 Five DVD 5.1 Channel Home Theater Audio System System Logo
Posted on Sep 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My DVD HT-Q9
My dvd model ht q9 does not function but when on it will display protect then goes off
Ginko
Level 3:
  • Samsung Master 19,396 Answers
  • Posted on May 04, 2009
Ginko
Samsung Master
Level 3:
Answers
19396
Questions
25
Helped
8078053
Points
55462
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mi HOME THEATER WITH DVD HT-X1 dice protect y se apaga
Mi HOME THEATER WITH DVD HT-X1 dice protect y se apaga. q debo hacer
How do I shut of the Protection on the Samsumg HT TP-33 in order to play a DVD
If you mean the unit is self protecting due to a short or overload, disconenct all the speakers and see if that helps, then troubleshoot the cause. Otherwise, it needs service.
http://www.retrevo.com/support/Samsung-HT-TP33-Home-Theater-Systems-manual/id/357dj788/t/2/
Then there's this....
Copy Protection
Many DVD discs are encoded with copy protection. Because of this, you should only connect
your DVD player directly to your TV, not to a VCR. Connecting to a VCR results in a distorted picture
from copy-protected DVD discs.
• This product incorporates copyright protection technology that is protected by methods claims of certain
U.S. patents and other intellectual property rights owned by Macrovision Corporation and other rights
owners. Use of this copyright protection technology must be authorized by Macrovision Corporation, and
is intended for home and other limited viewing uses only unless otherwise authorized by Macrovision
Corporation. Reverse engineering or disassembly is prohibited.
Why does the Samsung Home Theater DVD player display the word PROTECT then does not work?
if the speaker connections are not properly or anything wrong in dvd drive it goes in protection mode.remove all the speakers and insert the cd and see if it works with headphones. if it works check all the speakers one by one
SAMSUNG HT-Q9 displays PROTECT and then switches off?
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Usually a protect fault will indicate a bad transistor in the amplification section. I suspect that the control circuit is sensing a fluctuation in the power supply and going in to protect mode. (assuming that the protect circuit itself is working properly) If a voltage is too high the unit will go in to protect mode to prevent damage to the speakers and the rest of the unit. Expect a 60 to 80 dollar repair charge depending on how many parts need to be replaced and what the repair labor rate is in your area.Hope this will help........
6helpful
3answers
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
1helpful
2answers
My HT-TX75 DVD flashes a message
First thing to do is disconnect all your speakers at the back of the receiver, then turn it back on. If it does not go into protection, post a comment and I can walk you thru troubleshooting. If it still goes into protection, your unit needs to be serviced. Hope this helps
Samsung HT Q9 wide (16:9) problem
hi just press the easyview button and it will be fixed
2answers
Samsung dvd home theater HT d5610
This sounds like a short circut (check speaker and other conections to make sure none are touching each other or a metal contact!
That should fix ya!
3helpful
Samsung HT-Q9
1. power on
2. the tray with no disc
3. press "enter" on the RC
4. then press 84269
5. press "enter"
6. the dvd player will turn off
now it's region free
My pleasure Did it on mine works 100% region free now
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
