SOURCE: OVEN will not heat
I have the same model, 3 yrs old, and the exact same thing happened. KitchenAid made the appointment with a repair company and when the tech came out the first thing he said was "you can never use the self cleaning cycle because this always happens.' He replaced the thermal fuse thermostat and said that a lot of times the digital panel will go out and that will cost around $400. The cost of the thermal part was $80 plus his $90 labor charge. I called Kitchen Aid back, and they swore they never heard this complaint...all you have to do is look on line to see it is a major complaint!
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
SOURCE: Dacor CPS 130 oven will not heat
This model actually made this way. Sometime you can not see the thermostat because of the bracket in front of the door latch. When you remove grill panel under control panel you gonna see this bracket. It pulls out very easy. Behind the door latch you will see thermostat with red button on the middle. Before resetting this button make sure you disconnect electricity.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
SOURCE: My Dacor wont heat, broil or convection after self cleaning
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
