Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
Anonymous Posted on Oct 11, 2011
How do I reset a lifefitness Treadmill 9500HR from miles per hour to kilometres per hour
ernesto cuadra
Level 3:
Top Expert:
  • Life Fitness Master 12,223 Answers
  • Posted on Nov 28, 2011
ernesto cuadra
Life Fitness Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081371
Points
34431
    • 1
Switchthe power off without unplugging the machine. Do not take the safety key out ofits place.
    • 2
Inspectthe bottom of your console. The calibration switch is in a small hole. Insertthe eraser end of a pencil into the hole and softly push the button. You willsee CL11 on your console after you push this button.
    • 3
Usethe Speed + or - key to select MPH or KPH. Push the Power key to save yourselection.Sincerely.E.CUADRAMANAGUA, NICARAGUA C.A.
Roger Black JX 286 - is the distance on this treadmill measured in miles per hour or kilometres per hour?
Firstly look Via Google, for your needs, Ive found some info on the Argos website.
How to adjust unit measurement
How do I change from mph to kph on a 9500 hr lifefitness treadmill please
We have Lifefitness 9500HR Treadmill. I am getting a Bad Controller Error. We have two 9500HR models. I swapped out Controller, with working 9500HR and still get Error. Keeps going into Notify Maintenance....
I would suggest swapping the consoles to see if the problem follows. If this does not help you figure it out, you are more than likely looking at a wiring issue.
I have Lifefitness 9500HR, commercial, when belt is running it produces load rubbing sound and when somebody is in it, the sound gets louder. What causing it?
this happen because lack of maintenance schedule, shut down and produce enough friction and loud, and shut down for to protect the electronic systemLUBE Inmediately the deck belt,maybe is time to replace the deck belt. by WORN.
2) LUBE THE rollers bearing too
3) test the motor voltage input, if there are the MOTOR need REPAIR.see my persosnal TIPS.
God bless you
7helpful
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
How do I access the service menu on a lifefitness 9500HR treadmill?
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
5helpful
Manual for lifefitness 9500hr treadmill old modle
Just call Life Fitness and they will send you one via e-mail attachment.
(800) 351-3737 between 8 a.m. and 5 p.m., CT Monday through Friday.
stephen
2answers
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
