If these are model numbers,you would need the part number of the IC. If the IC is specific to Technics, it is most likely to be unavailable. If you would like more information, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
The clicking sound will be a relay for the protection circuit. That could be faulty, but first check out the main devices on the main amp section. Those attached to the big heat sink. If you see a single IC amp that could well be faulty.
NAother option is to fix a universal amplifier kit into the set which powers from the same voltage preferrably a MOSFET drive which are very much available in the market and can be suited into the set. They will alos be very effficient but take care tto do the fixing mechanically , connecct the right power and groung with good shielding. Disconnect the old amp totally and use the power lines that come to the IC. I hope this works for you. Good day
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Well whatever is playing up sounds like it might be getting too hot to me. In any case it's something common to both channels. Just have a look on the heatsink to see if it uses a single IC for both channels, they are can cause lots of problems!
The IC might be marked STK with numbers after the letters. That is the part number too for ordering a new one.
I have done a followup with Technics Parts agents in the US, they will get back to me and then me to you shortly :) A vote as FixYa would help improve my ratings. Thanks
