You can order the part:www.fitnessrepairparts.com
or www.gymparts.com
www.treadmillpartszone.com
You must locate to side from the power switch you must find the fuse holder and replace the fuse with THE SAME SIZE+CAPACITY+VOLTAGE INDICATED FROM THE SAME FUSE.
Remember if the fuse is Blown again or continuing you have a short circuite in a) Transformer b) Main Motor c) Main Controller Board d) Faulty ground in your receptacel from the wall very carefully.
attached the block diagram that I did for to illustrate to person like you, good luck. sincerely.
