20 Most Recent
Bowflex TreadClimber TC5500 Questions & Answers
Lights up but when pressing Quick Start it automatically shows the lady liberty,etc for a moment then goes back to the Bowflex logo and nothing else. Help!
I was having the same issue to a T. I called Bowflex tech support, they told me that without a doubt the main pc board that is under the treads needed to be replaced for $515. I then trouble shot myself and got it up and running in minutes for $0. Take of the plastic top from the pc board area, unplug the little clipped in 2 wire plug labelled Fan. It litterally says fan on the board and you can see 2 wires going right to the fan. Once that is disconnected try to Quick Start. It should work. You can either replace the little fan for $6 @ radio shack or run a fan your self simply by facing your own in the same area. Most people are running a fan for themselves anyway, just aim for both. Good luck.
11/19/2023 1:45:33 AM •
Bowflex...
Answered
on Nov 19, 2023
I keep getting error code 0AB
Error code 0AB on a Fisher & Paykel refrigerator may indicate a problem with the evaporator temperature sensor. The evaporator temperature sensor is responsible for monitoring the temperature inside the freezer compartment. If the sensor is not functioning properly, it may send incorrect temperature readings to the control board, causing the error code to appear.
Some possible causes of this error code include:
- The evaporator temperature sensor is malfunctioning and needs to be replaced.
- The wiring connections between the sensor and the control board are loose or damaged.
- The control board itself is malfunctioning.
If you are seeing this error code, I would recommend checking the wiring connections and the sensor and if they are ok then the control board may need to be replaced.
It is best to contact a qualified technician or the manufacturer for help troubleshooting and repairing the issue, as working on refrigeration equipment can be dangerous if you are not properly trained and equipped.
