Anonymous Posted on Oct 01, 2011
How to open a425 subwoofer - Dell A425 Computer Speakers
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1379
Points
Pull off front plastic grill to access four screws on the speaker itself. Unscrew 10 screws on back to pull out the power board. The transformer is screwed to the bottom (4 screws).
  • Anonymous Aug 08, 2012
    Hi, how exactly is the front plastic grill pulled off? I've been unable to get it to move even slighty.
Schematic Diagram for A425 amplifier
Did you ask Dell for help? Just don't hold your breath - they would rather you get a new one from them but U can try. If nothing, check it out on Google - might get lucky!
tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT
PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1
PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD
PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
I need the driver for it, i have no sound
Anonymous,
There are no drivers for the A425 speakers. Make sure the power cable is attached to the speakers as well as the speakers plugged into the correct jacks. If your speakers are plugged in and powered on and u still have no sound; check to make sure the sound card drivers are installed.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
1helpful
Dell a425 disassembly
I found this URL for you that shows a Dell forum where you could probably get all the info you need. It also has specifications for all the internals should you need to replace something. Good luck and be safe. I learned to hate capacitors a long time ago. :-) http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_E876EF53BCA3F058E030030ABD6260B2&isLegacy=true
A425 subwoofer, more bass? wires came off, no bass managment.
I wouldn't cross wires or leave one disconnected. Can you solder the wires back on the the control knob? Did you feel the subwoofer cone to see if it's working at all? I would guess the wire you didn't connect, is the subwoofer wire. Try putting it back to original cofiguration and solder the wires in place.
2answers
How do i hook up a Dell A425 subwoofer to a regular stereo sytem i cut the wires and i need to know which two wires i need just for the subwoofer
describing a pin-out to people who are not electrical engineers is like explaining to someone how to build a clock when they asked what time it is.
Looking at the orange VGA connector on the back, which two holes have the wires that go to the two sides of speaker wire for the subwoofer? Do i have to do anything else to make it just work like a simple speaker and just be controlled by the amplifier (receiver)?
Like seriously, am I asking it simply enough? Which two holes in the orange female vga plug on the back of the subwoofer correspond to the + and - speaker wires that go to the "subwoofer" hookup on the back of my stereo? I don't care about what each pin does because those words don't mean anything. I don't understand. WHICH. TWO. WIRES.
and then is there anything else i have to do like stick a paperclip from one hole to another and hope it doesn't explode?
Also, I don't know what the numbers of the holes are. so saying "pin 9" or whatever is meaningless without a diagram.
thank you for my ted talk.
My subwoofer and speakers wont draw power when i plug it in, could it be the fuse or something else?
The Altec Lansing A425 doesn't appear to have a fuse. Check for a circuit breaker on any surge protectors it might be plugged in to and make sure they haven't been tripped. Confirm that the power cord is firmly plugged in. Additionally, you could check the wall transformer with a multimeter to make sure it is providing the correct voltage needed by the speakers. Check the back of the subwoofer for a hidden power switch. If everything is plugged in and turned on, but you still don't have power, you will either need to open the device up and troubleshoot it or replace it.
Can i hook a sub woofer up to m-audio av40s
odwalxo, you can't add a subwoofer because the only output you have on those m audio speakers is for the "other speaker of the set via regular speaker wires". Everything else it's just inputs.
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
