GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Sep 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 65 Answers
  • Posted on Sep 29, 2011
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
65
Questions
0
Helped
21090
Points
120
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
SOMETIME MICROWAVE OVEN PANEL GOES DARK AFTER USE. REPLACED 3 DOOR SWITCHES. WHEN MICRO IS PLUGGED IN NOW, IT WILL NOT SHUT OFF
Please don't type in all CAPS, it is considered SHOUTING and harder to read.
Dangerous for 'ordinary' people to open up microwave ovens and mess around with safety microswitches. They are just a simple switch, open or closed, so it doesn't matter.
https://www.fixya.com/support/r29874712-repairing_microwave_ovens
or contact GE direct. We aren't them.
2helpful
GE Profile microwave oven PEB7226SFSS quit warming food but appeared to be on/operate with light on/timer counting down. Installed door switches-now the microwave "works" only when the door is open
Sounds like on reassembly you reversed wires to door switch.
switch might have letters C NO NC (common, normally open, normally closed) one wire goes to C common, the other to NC normally closed. Try reversing the wires.
If you use meter measuring continuity meter on C and NO should be high resistance until you press switch.
meter C to NC measures low resistance until you press switch then measures high or infinity (open)
Microwave only runs with door open (!?)
"There is some charring around one of the interlock switch terminals"
You have a bad connection. The connector and the switch it goes to should be replaced.
Our help file on door switches is here.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
2helpful
Every time I open the door to the microwave, it goes on automatically. Even if I press the button on the door, the microwave goes on. Should I just buy a new one, or is it an easy fix?
most likely the door latch assembly and or the door switch has failed... there are approx. 3 micro switches located where the door closes... these switches all operate items such as the cooling fan,timer, clock assembly etc... sounds like one of these micr switches have failed and will require getting inside to exam with a meter and check contuinity on close and open when switch is open...good luck to you...
1helpful
We have a relatively new (about 6 weeks old) GE OTR microwave--model is JVM1540SP1SS. Yesterday it started "running' even when there isn't any food in there and before we push any buttons. When the...
It sounds like a sticky door switch. There are several switches operated by the door latches to keep the oven from operating with the door open. It's possible someone got a little too rough when closing the door, which can cause misadjustment.
Since the oven is so new it will still be under warranty, though. Why not let GE fix it? You just need to tell them it's not working properly. First call the retailer where you purchased the oven. If they arranged installation they probably also handle service. Otherwise you can contact GE's customer service as instructed in your owner's manual to find out how to handle the repair.
The microwave runs, it does not heat (model JVM1431BA 001. What part do I need to replace?
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
regards .
please rate !
2helpful
Microwave runs with door open
there is a safety switch located on the door frame chances are it need replacing since it is staying activated
GE Spacemaker xl1800
A simple test is to place a piece of bread in the microwave ( it heats up very fast) and then if your microwave was actually ON and generating RF, the bread would get hot very fast.. If it remains cool then only the fan is on. It appears that you may have a faulty door switch thou because once you open the door, your microwave should be off..
Are you sure the VENT is not on? That blower will operate regardless of the door open or closed so you must switch it OFF.
1helpful
Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
