I suspect that you can go to Walmart and find a cable which converts USB (computer) to HDMI (TV) rather inexpensively. It will have a USB male connection on one end and an HDMI male connection on the other. These are available in various lengths and increase in price with the increase in length, as you might expect. Yours is not a big problem. . .
SOURCE: tcl tv 2913n
Simultaneously press “DISPLAY” button on remote handset and Volume- button on the front panel of television receiver for 6 to 8 seconds to get the various service menus.
· To access any parameter , use Up/Dn keys of Program/Channel
· To change value of any Parameter, use +/- keys of Volume
· To exit POWER switch off the set
SOURCE: no picture when tv powered on
When power on and input set to hdmi1, there is no image appears
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
