20 Most Recent
TCL L40FHDM12 40 Class LCD HDTV - 1080p, 1920 x 1080, 16:9, 60Hz, 8ms, Questions & Answers
Turning on tcl tv
there wil be touch buttons on the side . press standby button.tv wil b on
TV showing a green faded screen
If the problem is same with different input devices and you have ensured
the are no loose contacts in power outlet, RC jack, cable and sockets,
the TV needs servicing.
When i turn tv on the blue light comes on at the bottom signifying its on but there is nothing on, when i hit the power button nothing happens and the blue light just stays on all the time when its pl
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Tcl l40f10f
try update your TCL TV firmware by current update version file from USB stick
https://electronics-tricks.blogspot.com
