Lots of older watches needed to have the hands advanced 24 hours to advance the date one day. Fortunately most modern watches require the hands to be wound backwards to advance the date, often at the rate of a day per hour. A combination of the backward and forward winding of the hands made adjusting the day and date much simpler and quicker.
A few premium watches had a third position when pulling out the winder, a position dedicated to adjusting the day/date
When you pull the stem out all the way (two clicks) it should set the time. Pulling the stem out one click you noticed sets the date, you turn it one way for the date and in the same postion you turn it the other way for the day. For some reason on some watches the day will stick, if that still happens you will need to turn the hands around and around until you get to the right day, then keeping in mind the 12 hour interval you are in... set the date and time. If the day still does not change then you need to return the watch if its new or send it to timex! Caution: when sending a watch to Timex sometimes they send back a different watch without asking so if its sentimental do NOT send it to Timex!! Hope this helps! have a great day!
HI..
HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
Step 1
Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
Step 2
Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
Step 3
Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
The trick is to turn the ring to the "Date" setting, Pull the stem out once for the Month and Date. Pull the stem out (hard, but gently) a second time for the Day of the week. Each pull will be confirmed by a 'beep. Be persistent and good luck.
