3Com Baseline Plus 2226 24Port Ethernet Switch (3C16475CS) Logo
Posted on Sep 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I would like to find out a manual for 3Com Baseline Plus 2226 24-Port Ethernet Switch (3C16475CS) Could you help me, pls. I would appreciate about your supports. I have a network system equiped 3C Switches and i need to find out manual for them.
Justin
Level 3:
  • Master 2,072 Answers
  • Posted on Oct 16, 2011
Justin
Master
Level 3:
Answers
2072
Questions
0
Helped
432137
Points
5629
How to factory reset a 3com Baseline 2824 switch
A very simple solution to r epairing all by yourself is getting help from handbooks, they're very detailed and complete in every way so for me it was my b est source to repair
one of the top sites for this is https://big-manuals.com/
I have Allied Telesyn Switch I want to return to factory default system. I saw that I can connect to the HTTP service from my pc. what's the switch port I have to use?. What's the subnet ip for this...
To make it a factory reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Firmware update for 3Com 2952
Don't let the switch name fool you, HP calls it the HP 1910.
HP 1910 48G Switch Fixed Port Web Managed Ethernet Switches HP JE009A ABA
Technical Notes:
"The HP 1910-48G Switch (JE009A) was formerly sold as the 3Com Baseline Plus 2952 (3CRBSG5293) and may ship with this product labeling.SFP ports and copper ports work simultaneously, independent of each other to give a total of 52 Gigabit-capable ports."
Firmware download from HP:
My Networking HP Official Site
How to reset the switch of 3C16475CS? (if no reset button)
It's called a recovery button and it is inside the switch. You need a paper clip or pin to press it. It is the tiny hole on the back of the switch
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c02581571/c02581571.pdf
Page 9 shows the hole it is labeled "8"
Comment back if you need more help.
P.S. HP owns 3Com
I forgot my admin password on my 3com baseline switch 2226-sfp. i can't remember. Can you please help mo to reset my baseline switch to reset the password only. Thanks jenry
If it's the Power Plus (3C16475BS) model, there should be a reset button inside a small hole on the back. "10 - Recovery Button" Inserting a paperclip or similar to reset. If it's not the Power Plus model and is in fact (3C16475A), this is an unmanaged switch, with no administrative capabilities. You don't need a password.
http://www.3com.com/products/en_US/detail.jsp?tab=features&pathtype=purchase&sku=3C16475BS
4helpful
How do i Reset or break in to get reset my password on 3Com 2948 Baseline Switch 48Port SFP Plus
The resetting of the password requires the installation of a console cable to the console port.
Be sure the terminal emulator program is set to VT-100 management using compatible, 38400 baud rate, no parity, 8 data bits and Console connection one stop bit.
Use the included cable, or be sure that the pin-out complies with a standard null-modem cable
Once the cable is connected, reboot the switch. Type a Ctrl/C until you enter the failsafe mode. This will be denoted with the prompt: “CFE>”
At the prompt execute the following commands:
CFE> passwrd
CFE> reset -sysreset
At this point the password has been reset.
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
