Breadman TR500 Bread Maker Logo
Anonymous Posted on Sep 12, 2008
Breadmaker TR520: Page 5 instructions, #4 says "Before first use, operate Bread maker on FAST BAKE to burn off mfg oils. Follow instructions outlined in the OPERATIONG INSTRUCTIONS section of this INSTRUCTION MANUAL." The OPERATING INSTRUCTIONS are on pages 17, 18, 19 and 20. In those pages, there are no instructions as to how to do this, only instructions on how to program the bread maker and make bread. Help, please.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
976
Points
I ignored the instructions which told me to follow instructions which were left out of the booklet. I just washed the breadpan and paddle with hot water and dish detergent, dried them, and made bread. Everything A-OK.
2answers
How do I get a manual
http://kitchen.manualsonline.com/manuals/mfg/sunbeam/5891_1_2.html
1helpful
Is there a replacement flapper for this breadmaker
YES IT'S CALLED A BREAD KNEEDER YOU CAN BUY A NEW ONE FROM THE AMAZON WEBSIT........TYPE IN THE SERCH BAR AT AMAZON BREAD MAKER PARTS..........
THEY WERE LAST WEEK £6.05 EACH.....
I would like instructions in English for a Twinbird breadmaker.
Rose, Check the attached links,instruction and guides,manuals for your bread maker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Twinbird breadmaker english manual
http://www.useandcaremanuals.com/pdf/TR520.pdf
Free Bread Maker User Manuals ManualsOnline com
1helpful
I managed to scratch the loaf pan and am looking to buy a replacement for my Tr520 Breadman breadmaker. Not proving to be very easy. Help!
Check out ebay. They seem to be expensive....For some reason I think the manufacturers don't sell the bread pans separately so you have to buy a whole new machine.
http://cgi.ebay.com/NEW-Breadmaker-Bread-Machine-Pan-Breadpan-TR875-TR520_W0QQitemZ380140130482QQcmdZViewItem
Hank
1helpful
Before using the first time.
yes just run it briefly without any ingredients in. give it a wipe with kitchen paper and you are ready to go! =]
1helpful
Initial use
YOu want to clean out the interior with a damp (NOT WET) cloth then dry it - before running it empty with the breadpan and paddle in place. My manual told me to follow the instructions for the Making Dough and Baking Bread section of the Instruction Manual. (I have TR5200BC) I'm referencing page 23 of my manual and starting from STEP 5. Comments in { } are mine.
5.Insert the Bread Pan into the Bread Chamber - press down and make sure it snaps securely into place. {note - you may find that you have to rotate what looks like the propeller on the bottom of your bread pan until you get used to placing it the chamber}. If the Bread Pan does not snap securely into place, remove Bread Pan. Wearing oven mits {to avoid sharp edges}, place fingers behind Bread Pan clips and gently pull away from oven wall. Insert Bread Pan again.
6. Close the Lid. Plug into 120V-60Hz outlet. The Breadman will beep and the display indicator will light up with flashing zeros.
7. Press the SELECT Button to choose the Cycle you want. Each time the SELECT Button is pressed, it will beep and the Indicator will move to the next Cycle in the Display Window.
8. {Skip step 8 - Crust selection}
9. Press the LOAF Size Butoon to select 1LB
10. {Skip step 10 - Extras nuts/fruits}
11.Press the START Button
12. Press STOP/RESET Button and open the Lid. {If you want to remove the Bread Pan at this time be sure to use oven mits - I did mine the night before I wanted to use it and let it cool over night. Before I used it to bake I rinsed out the Bread Pan with warm water and mild soap}.
This will take about 2 hours then you are ready to bake. Enjoy
1helpful
3answers
Replacement mixing paddle for cbm 310 automatic breadmaker
07XTM34923 AbtecParts.com
Toastmaster Bread Machine part - works great, according to other website
I ordered mine today
1helpful
4answers
Instruction Manual
go to hillbillyhousewife.com and they have instructions for bread machines. I have used 3 different models of breadmachines and they work about the same. The site also has recipes. I use this recipe most of the time for fast bread that takes one hour for the Toastmaster TBR15.
I cup plus one tablespoon warm water - I use warm water from the tap but you can use a cooking thermometer if you like.
2 tbs oil
2 tbs sugar
1 tsp salt
3 cups white flour OR 1 1/2 cups white and brown flour
1 tbs yeast
Adding glutein will make the bread have a smoother texture. Follow the directions on the box.
Add ingredients in order.
Program breadmachine to fast bake and let it go. You will have fresh baked bread in an hour.
Hope this helps
Jan
Top Breadman Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
