There are tools for hooking and stretching a spring but, if you can grab it with some vice grips, have the kick up where the spring stretch would be the least, you should be able to get the spring on.
No, there is no special tool for installing the spring. I use a pair of side cut pliers to grab the spring with and stretch it on. If you've got a piece of strong steel wire, you can loop that through the spring hook and wrap the loose ends of the wire around a piece of wood and use that to stretch the sping. If your bike has a kick stand bracket that bolts on, you can loosen the screws and get some slack in the kickstand lever itself. Position the kickstand where the distance between the places where the spring connects is as short as possible.
Good Luck
Steve
