20 Most Recent
Casio Pathfinder PAS410B5V Wrist Watch Questions & Answers
Replacing watch band on pathfinder pas410
Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
Rate me, plz.
How to reset 2872 casio ?
If a Casio watch has a display readout that says "OPEN", the watch isn't closed properly. Check if all the parts are inside the watch and make sure the watch is tightly screwed shut. If the watch was serviced at a repair center you should return it to have it checked (for missing parts).
After 5 days of darkness, watch will not turn back on
The watch has a rechargeable power cell inside the cover. Remove the back, find the button batter, and replace it. It may be the old original or dead cell. Once you replace the cell, the watch will refresh and be back to normal. The only problem if that fails, the mini-computer brain died.
