1998 Toyota Camry Logo
Posted on Sep 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 98 Camry Le and the door locks lock automatically shortly after the doors are unlocked and the alarm will set also. What could be the problem? Alarm Control Box?
Anonymous
Level 3:
  • Master 977 Answers
  • Posted on Sep 01, 2011
Anonymous
Master
Level 3:
Answers
977
Questions
Helped
314229
Points
2129
If you use the keyless entry to unlock the vehicle & don't open a door within 30 secs.the vehicle will automatically lock & the alarm will reset,if you unlock it with the key this shouldn't happen.....cheers.
Peugeot 508 RXH: I cannot lock the car with the remote. The doors lock, but unlock again. The car detects open doors correctly. I can lock the doors with the dashboard button.
If you have 2 remotes does it do the same thing with both of them?
I/We have a Honda FRV and if you set the alarm from outside the car ....which locks the doors ...and the doors are opened from the inside, (yes I have set the alarm whilst still in the car,) this unlocks the doors as the drivers door has the master central locking switch on it. If I close the door withing a few seconds the alarm reactivates itself and the doors relock automatically
Presumably when your doors unlock the alarm is disarmed? Maybe your issue is linked to the receiver in the security system?
There is a difference, presumably, between you locking the doors from the dash as opposed to doing it from the remote control, the security system is not armed in the former, only the doors are locked +
GOOD LUCK
How do i manually release the rear door on a ssab 9-3 2003 as the door module has failed
Trunk Lock After Closing
Desc.: What happens to the trunk lock when closing it.
Settings:
Yes: Automatically lock Boot on closing
No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
Desc.: Should the trunk be locked at drive off or after 30 sec.?
Settings:
Yes: Trunk/Boot will automatically lock when vehicle increases speed
No: Trunk/Boot will remain closed, however will be in the unlocked
condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
Desc.: When the is removed from the center console should door/trunk
be unlocked?
Settings:
Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
the Ignition Switch If Driver frequently locked all Doors when
driving
this feature would be beneficial.
No: Doors and Boot will remain in the same condition as they were
prior
to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock
Mode
TSL at Second Press: All Doors will lock in Deadlock mode at the second
press of the Remote.
* Lock /Unlock Acknowledge
Settings:
None : No acknowledge will be visible
Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
Settings:
This Feature can be turned on or Off .Yes / No can be selected.
Low Beam Automatic / Low Beam also in Position 0 (light switch)
Yes / No
- Daytime Driving Lights can be activated
* Parking Lights
Settings:
Act as Lead Me To the Car Light.
* Park Light On Reminder
Settings:
On / Off
If Ignition is turned Off and the parking lights are active, Driver will
be warned if set to on.
* Show Trailer Light Outage
Desc.: REC will detect blown trailer light and display on SID
Settings:
Yes or No
* Trailer Light / Fog Light off
Settings:
Yes: Fog Light Rear will be disabled When Trailer is connected Yes
No
* Horn Lock Unlock Acknowledge
Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
- Panic Button / Locking Switch
Central Locking Switch Driver /Passenger
Settings:
- Panic Button on Remote and locking switch inside vehicle will
activate alarm
- Panic Button will activate Alarm only
- Locking Switch inside vehicle (driver /passenger will activate
alarm only
- No Panic Alarm function required.
* Unlock Logic
Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the
Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
& Fuel Lid will unlock when door
switch is activated
* Remote unlocking One Press
Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the
Remote is pressed
Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
Fuel Lid will unlock when the Remote
is pressed
1helpful
3answers
TDS 3-button keyless remote operating instructions please
RED opens the drivers door, BLACK opens all the doors, and GREEN turns on the head lights
5helpful
3answers
Driver side door doesn't lock or unlock with the remote. The rest of the doors work fine.
Does the Driver side door lock and unlock from the lock switch inside? If not then you have a bad motor or bad connection to the lock/unlock motor inside the door.
2answers
My 98 camry door lock is stuck in the locked position
front door? try unlocking it with the key from th eoutside, may be linkage or the door lock acuator bad.
2helpful
4answers
1helpful
98 camry door lock will not turn....
really sounds like the tumbler pins are stuck in the cylinder of the lock. mite want to spray some lubricant like(PB Blaster)or WD-40 in the cylinder key hole and push key in and out to see if tumblers will release..gd luck..chris
1helpful
93 Camry v6 LE Door Locks
I have sent you the wiring diagram. Please respond if you have any questions.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
