Apple iPad 64 GB 3G Tablet PC Logo
Posted on Aug 31, 2011
Ipad is lockd and i have forgotton password - Apple iPad 64 GB 3G Tablet PC
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
479
Points
If you cannot remember the passcode, you will need to restore your device using the computer with which you last synced it. This allows you to reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced with the device, you will be able to unlock the device for use and remove the passcode, but your data will not be present.http://support.apple.com/kb/HT1212
For restore instructions, see this: http://support.apple.com/kb/HT1414
I forgot my ipad passcode and never synced to a computer
I would just take it to a instore mobile phone repair man/or lady usually chinese are great at what they do not expensive .
Ipad been disabled but also forgotton id and password now needing activation lock please help
Contact apple to reset your account. Then you should be able to connect the ipad to a pc or mac with iTunes and reset or restore it.
1helpful
2answers
I can't unlock my Ipad, it won't accept my password, how can i change my password
If you have synced your iPad with iTunes before you forget your password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked tablet while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPad without any passcode. And you can set your new password on iPad.
http://www.leawo.org/tutorial/how-to-reset-password-on-iphone.html
1helpful
A disabled ipad.
When you've forgot the lock screen password of your iPad tablet, you get 6 tries of the password entering. After that, the only way you could do is restore you iPad to Factory Settings, which would then no doubt delete your data and files on iPad. The lost data and files would not be backed up on iTunes then. In such case, the only way you could recover data and files from locked iPad is to use 3rd-party data recovery software app. Feel free to read this article to know how to recover files from your locked iPad.
Forgot iPad Screen Lock Password How to Recover Data from Locked iPad
How do I transfer my new password to my new ipad as I cannot use
You cannot transfer a password. Each device has its own password. If it was possible to transfer a password, any stranger from another device could transfer their own password to your ipad, then you would be locked out of your own personal ipad.
Forgotton password
IN YOUR YOUR ACCOUNT CLICK , Forgotton password follow in struction
Don't remember password for ipad
You don't need to know your password for the iPad. As long as you know the password for your iTunes account, you used to setup the account on the iPad for. Connect the iPad with the computer and open iTunes and give in the password for the iTunes account. Apple will unlock the iPad and you can setup a new pass code for the iPad.
When you forgot your iTunes password, you have to contact Apple and prove you are the legal owner of the account.
Use this link to find more support for that:
Apple ID Support
Ipad password reset
In fact, there are different ways to reset iPad password. You can follow below method to have a try.
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
For more methods, check: How to Unlock iPad?
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
