Sharp R-930AK Convection/Microwave Oven Logo
Posted on Aug 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven turns on does not heat food turntable does not work but when door is open turntable starts turning. Any thoughts.
William Miller
Level 3:
  • Sharp Master 9,179 Answers
  • Posted on Nov 21, 2011
William Miller
Sharp Master
Level 3:
Answers
9179
Questions
Helped
4481691
Points
21747
Bottom door switch or mount.
The service manual is here.
You can order parts from Encompass here.
Why is my turntable in my microwave oven not turning?
i suspect you have a bad door interlock
if you dont know what too do take it to a repair person
2answers
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
3helpful
Turntable will not rotate and food will not heat up.
If it is not cooking and the turntable will not turn, this sounds like the secondary interlock switch is bad. Almost always this failure is caused by opening the door when it is in a cook cycle. Pushing the stop button before you open the door will prevent this in the future..
MMV5100AAB Over the Range 1500 watts 3amps -turntable does not turn -does not heat -light works- unit makes loud running noise but will not turn off -must open door or unplug to turn it off. Never any...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Makes grinding sound when turned on---does not heat---turntable does turn
Grinding sound may be the turntable not sitting properly on its support. Regarding the heat issue, check the door safety interlock switches for proper function.
As you use your oven, open the door while it is running, arcing occurs on the little contacts and they eventually burn. When they cannot make contact, the oven doesn't know if the door is closed or not. Forget what YOU know about the door ... the oven must know and it knows by the information it gets from these switches. Door open, the oven will not turn on the heat.
Thank yo for your interest in FixYa.com
My sharp R-798 has stopped heating food and the turntable no longer rotates?
Please check your door safey interlock micro switches.
If you need help with this, please let me know.
What frequently happens is because you probably open the door while the oven is running, (like most of us do) the little micro switches get burned and eventually cannot tell the oven that the door IS, indeed, closed. When the door is "open" (forget that you know the door is closed - the MACHINE needs to know it too) the oven will not turn on the heat.
If you need more info, let me know please.
2answers
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
1helpful
MIcrowave light and turntable are working, but food comes out cold
I suspect the magnetron or high voltage transformer, and either part's cost or labor would probably be about the same as the cost of a new comparable unit.
Turns on by itself and turntable does not rotate
You may have a control board issue. Thank God for safety switches.
This is a problem that an integrated circuit tech. can repair, but it may be costly.
Decide how much you want to put into this oven vs. buying a new one.
Contact me once you decide and I can help you find a service center.
Thank you,
Dave E. (Illeagle)
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
