I had the same problem, SAMSUNG did not want to tell me how to fix so I jumped in with research I found that after you remove the power supply, i.e. plug, 1) you need to remove the dishwasher and turn it upside down. 2) There is a white sensor tray; 12x12 approx. on the bottom held in with two screws, remove the screws and use a flat head screwdrider to undo the clips holding the tray in place. 3) Dry the tray and sensor tips with a towel and replace the tray. Bammmm, you have just fixed the LE(leaking error) code error.
The "Check lint screen" light is just a reminder to check the and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty, it's just a reminder. The "Check lint screen" should turn off as soon as the dryer is started. If it never turns off then the control board would need to be replaced in order for the check lint screen reminder to turn off, however the check ling screen reminder light staying on will not effect the operation of the dryer. Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Service engine soon has nothing to do with service or maintenance . Emission's OBD 2 engine managment system . Light on ! DTC'S - diagnostic trouble codes stored . Your don't know THAT ! Your best bet , take it to the dealer .
I may have fixed it. i have the same problem with my Casio Type-S on
getting stuck on registering applications. i found that as soon as your
keyboard lights up right before phone vibrates hold down the clear and
the power button at the same time as soon as the keyboard lights up. it
will for some reason by pass the app and work. but i had to keep doing
it every time i turned my phone off and back on.
Sound like you need a Ford dealer scan? A battery can short out and cause problems,but if it's start6ing, it probably isn't a shorted battery. don-ohio
