20 Most Recent
Casio G''zOne Type S Cellular Phone Questions & Answers
How do i remove a broken screen to replace with
Is just the glass broken? The LCD screen underneath the glass also could be broken. But if it is just the glass in front of that, go on ebay and search for the inside glass lens. Also, you can find directions to change anything at all just search it on google.
Phone just says searching for service. wont let me
when a phone is showing no network coverage, there are
possible ways you could look into,
Network setting in the phone.
Re-formatting
the phone or flashing it.
Hardware repair.
In your phone you
can check the network setting on your phone if it has been tampered with
you so can easily reset it.
Some times when a phone drops in
water or on the flow, and after then was not serviced might cause the
network reception to fluctuate .Some application downloads,Dirts or
malfunction of the phone can also cause a phone s network to disappear.
So
you can service the phone by taking it to a repair shop and tell them
you would like to service the phone for better service.
Hardware
repair, can also be checked only when the other options did not give
the solution. You will have to take that to a repair shop, to prevent
more damage of the phone. It needs professional handling .
Take
care.
Casio gzone
i set my boulder to nam2 on accident and my code didnt work after searchin for like 4 months on the internet i found this code ##7764726 (PROGRAM), SEND. SPC Enter 000000 after u enter it go to the nam settings select nam2 go to the second one its like MDN or somethin like that the last four digits should unlock it but u might have to take it to the store to get it programmed again but ull have ur phone back without losin any info u mightve saved on it
Cant send photos with messaging
text messaging is sms (short message service) and does not support pics try mms (multi-media service) this should allow you to send a picture with text
Casio G'zOne will not start or charge
Need more details. If the phone appears to turn on (you can hear or feel it do the startup sound or vibration), then the cable between the lower and upper halves might have broke. If the screen is broken or the case cracked, then it has been run over one time too many. If you have a second battery, try it with that. Some phones do not power on without a working battery, even if plugged in to charge. If that doesn't do it, then the mainboard is broke. It is waaaaaaay past time to get a new phone.
My Gz One Boulder's charger port broke off. I
The same thing happened to my Gz One Boulder. I sent it back to Verizon for replacement. The 2nd Gz One Boulder also had problems with the charging port within 2 weeks after I got it so I sent it back too.
I am now on my 3rd Gz One Boulder. I've only had it 2 days. Time will tell if the charging port on this one will hold up. Frankly I doubt it.
My best advise to you is get a different phone if you have the opportunity to do so.
Casio lost contacts
hi david -try too turn phone off then back on -if not re enter a few names and numbers to your contact list and see if it does it again -if it does you may be best to take it back to were you got it from -may just need a software upgrade --hope this helps mick
G'Z one phone powers on but just says loading
Probably your phone's operating software is corrupted, u need to re-flash it
U can remove the remove the memory card completely and then try to restart phone but generally memory card has nothing to do with it,
Screen stuck on registering applications
i may have fixed it. i have the same problem with my Casio Type-S on getting stuck on registering applications. i found that as soon as your keyboard lights up right before phone vibrates hold down the clear and the power button at the same time as soon as the keyboard lights up. it will for some reason by pass the app and work. but i had to keep doing it every time i turned my phone off and back on.
How can I download pictures with no screen with the G'zOne?
If it has a memory card, with photos stored on it you can put the card into your computer reader and download them. Otherwise, you need to see it you can find software (use google to search) for your phone and use cable to connect it to your computer. If neither of these work, trash the phone and chalk it up. Get one that uses a memory card.
I have an error message Registering Applications. Can't get past this screen
I may have fixed it. i have the same problem with my Casio Type-S on
Phone does not turn on
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
