SOURCE: unlocked may not be??
You need the sim card that's the same as the cell phones provider in order for it to work
SOURCE: "insert smart chip" eror message - smart chip is in but nothing
Hi there!
The first thing to try is cleaning the contacts for the smart chip, on the phone and the chip itself. Use a little rubbing alcohol on cotton buds and be careful you don't bend the contacts in the phone. If that doesn't remedy the problem, get your service provider to give you a new chip. They should be willing to give you one for free. If that doesn't fix it, then it is probably a phone problem. You may go to your service provider or any nearest mobile phone repair shop to have it fixed. You may also have the phone replaced if your budget allows it.
Happy holidays!
SOURCE: INSERT CORRECT SMART CHIP
your phone is locked to att network that means your phone will only accept att sim card unless you unlock it. you can purchase unlock code from website www.cheapunlock.com or www.unlockitnow.com or www.yourunlockcode.com
SOURCE: how to use india SIM in US mobile
this erroe happens because the phone may be locked
r else the gsm may not be supporting
indian gsm and us gsm varies a lot check the gsm
SOURCE: purchased in USA thru ar&t.brought to india it shows INSERT CORRECT SMART CHIP
go to a company store that your phone works with and tell them you would like an unlock code so you can use the phone abroad they should help you without a problem
