Samsung TL100 Digital Camera Logo
Posted on Aug 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you move pictures from your internal memory to your memory card on a samsung TL100 camera?
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Aug 19, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2201072
Points
38521
Find "copy"in the menu....it usually allows you to do what you need.
What is the process of uploading pictures from my samsung L200 to my computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
1helpful
2answers
Internal memory is full on our M580 Can not toke pictures
I copied this from Kodak website Good Luck!
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Follow these steps:
On the camera, press Review and then Menu.
Select Image Storage.
Change to Internal Memory.
In the menu listing, scroll down to Copy, and select OK.
Select a single picture, or select All.
When you have finished copying pictures, reset the Image Storage location to your original setting.
NOTE: You can also use a card reader to transfer picture files to a memory card. For more information on card readers and memory cards, go to KODAK Memory Cards
1helpful
I need to save some pictures from my SD Card to my camera's memory, but how?
Sorry, the TL100 only allows you to copy from the internal memory to a card, not the other way.
That probably wasn't the answer you wanted to see, but there it is.
2helpful
When I turned my camera on it said locked how do I fix this
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
2answers
How do you save pictures from the camera to the memory card?
Press the MENU button. Select the Setup menu (the wrench and hammer icon). Select "Backup".
2helpful
2answers
Samsung s850 cant copy from camera to sd card?
The Samsung S850 has an internal feature to do this. I have one. Put in your memory card and turn on the camera, push the button on the bottom right hand side of the lcd screen to view the picture, next when you see a picture (it can be any picture) push the OK button, this brings up a set of commands across the top of the screen, as you go across the commands one of them will be "copy to card". Select yes and the camera will copy the pictures to the card.
Transfering problem
Your camera has no internal memory so please buy a card reader and transfer your images into your pc and your next memory card
Move images saved to the internal memory to the optional xD-Picture Card
The images saved to the internal memory can be copied to the xD-Picture Card, but you cannot copy images from the xD-Picture Card to the internal memory.
Move images to the internal memory to the optional xD-Picture Card?
The images saved to the internal memory can be copied to the memory card, but you cannot copy images from the memory card to the internal memory.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
