Electrical Supplies Logo
Posted on Jul 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 3/4 hp Flotec 4022 pump. Prior to that I had a goulds 1 hp pump on the same 120 circuit with no issues. The Goulds pump housing started to go so I replaced it. Since replacing it with the Flotec I keep melting the load side of the pressure switch. I replaced the pigtail from the outlet. It shows 119.9 coming and 118.6 on the load side. It doesn't cycle on and off. I am clueless to why the load side keeps getting so hot.
jdthefixer
Level 3:
  • Master 747 Answers
  • Posted on Jul 06, 2017
jdthefixer
Master
Level 3:
Answers
747
Questions
0
Helped
314513
Points
2412
Hi Eglenni,
Here are the specs for your pump:
Thermoplastic Shallow Well Jet Pump 3/4 HP. This new revision of an "old hand" provides good pressure pumping from wells where the depth-to-water is 25' or less.
BODY CONSTRUCTION: Thermoplastic
HORSEPOWER: 3/4
MAXIMUM CAPACITY: 12 GPM
FLOW at 10' LIFT and 40 PSI: 9.7 GPM
MAX LIFT: 25'
MAXIMUM PRESSURE: 78 psi
PRESSURE SWITCH SETTING: 30/50
SUCTION PIPE SIZE: 1-1/4" NPT
DISCHARGE PIPE SIZE: 1" NPT
AMP DRAW (full load): 6.1 amps on 230v / 12.2 amps on 115v
VOLTAGE: 230v / 115v, 60 Hz
RECOMMENDED BREAKER: 15 amp on 230v / 20 amp on 115v
MAXIMUM WATER TEMPERATURE: 140 °F (60 °C)
Note that this pump can be operated at 115 volts or 230 volts (A/C) It may have come wired for 230 volt use from the vendor.
Make sure the pump is piped correctly.
There should be a wiring diagram either on the pump or in the literature so you can check to see how the pump is wired.
MAKE SURE
you have the pump wired for 115 volt use in your case. Also make sure the wire size is #12 awg for the power wiring.
Make sure all connections are tight. If you have an amprobe (an instrument that measures electric current) you can check to see how many amps the pump is pulling when it runs.
You said your old pump was 1 HP. This Flotec pump is 3/4 horse so there could be some pump performance loss depending on the well depth and length of the piping runs.
Here's the link to the website for the pump. There are additional resources available on the website:
Thermoplastic Shallow Well Jet Pump 3 4 HP
Goulds GT07 Irri-Gator Centrifugal Pump. It is a brand new pump is leaking.
Question edited for clarity.
Question moved from Cars and Trucks to a Goulds category.
Contact the maker of the supplier. It sounds like they left out a gasket or seal.
https://www.google.com/search?q=Goulds+GT07+pump+leaking+water
Wire diagram 4 gould gt20
Wiring diagrams for pump motors are usually on the inside of the cover of the wire access cover or on the motor tag. If this is a 1/2 HP motor it could possibly be wired 125V or 250V. Be sure to wire for correct voltage.
Why goulds septic pump buzzing
check for foreign objects jamming the impeller. have the motor tested for failure.
Pump runing
check the pressure control switch for correct operation
2answers
Gould water pump
I service all sorts of Goulds water pumps for a living but will need some more info to troubleshoot your problem. For starters would need to know what voltage feeds it, single or three phase, horsepower, type of controller (pressure switch, Variable Frequency Drive, Three phase across the line start etc.), what you are doing with it, pump model number, motor frame number, etc. etc.
Goulds pump
check for air leaks in the connections our your pressure switch is bad
How do I remove the impeller from a J5S pump?
most pumps arent made to be rebuilt and should just be replaced , its not worth fixing something and have it just go bad again.
I have a 1/3hp goulds pump not working i have changed the capacitor and the centrifugal switch but it still does not work; does not come on what must i look at next.
Check the continuity of the service wires. If they are good, check the resistance of the windings. You may have an open motor windings.
Top Northern Tool Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Northern Tool Electrical Supply Expert? Answer questions, earn points and help others
