Samsung TL 105 Digital Camera Logo
Posted on Aug 17, 2011
The Screen is blurry and the picture comes out blurry. Is it fixable I have reset it a couple times but its still blurry. HELP
3 Related Answers
Anonymous
  • 5 Answers
  • Posted on Dec 17, 2007
SOURCE: It became blurry
Are you using the auto function on the disc on top? If you are not it may be that your lens is open for too long.
I often get the same problem when using any other option as I'm not a pro, and when I zoom in very close on something far away.
Anonymous
  • Posted on Aug 23, 2008
SOURCE: blurry pictures and error 61:00
I am having the same problem too, i would really like to know how to solve this problem! i am seeing E:61:00. I just got my camera.
Anonymous
  • 11967 Answers
  • Posted on Aug 08, 2011
SOURCE: my pictures keep coming out blurry how to i reset
Go to "reset" in the set-up menu.
Blurry pictures on my Android tablet.
With it connected to WiFi select Settings / Reset / Factory Reset
That should fix it.
I have had this camera for a couple of years. Just recently the pictures are blurry with red haze. I have reset settings but still no good. Any ideas?
The sensor could be damaged, that is the red haze. You probably dropped it a couple of times and the inner optics are missaligned and/or damaged. The only thing you could do is get professional help from a local electronist, or contact your local Casio dealer for help.
Picture is red and blurry
try to reset the camera through the menu or else it is in need of repair
Finepix A350 - everything is blurry
I had the same problem. I tried a reset in the camera, also reformated the card through the camera once I had done a reset. At present it seems ok.
Taking pictures
Hallo
First, try to use different batteries. it can cause to long reaction times
Second, try to buy a faster memory card, it usually help for the time it takes to upload and see the pictures on the screen
about the blurry pictures
are you using M or a different mode?
7helpful
3answers
Blurry pictures and error 61:00
Blurry Vision
What are you looking at on the screen? Before or after the shot? The this point the taking sequence-point camera at scene look in screen blurry image - half press the release - autofocus comes into play- press all the way picture takes.Sharp picture in the taken images what are you doing?
How do i reset my camera
After selecting flash off mode the camera determine the shutter speed according to the available light which may be rather slow.Therefore either camera shakes or the object or may be both of them while taking pictures.That's why pictures are blurry. Keep camera steady or mount it on a tripod while taking pictures on flash off mode. Once u set the date & time and select OK I think it will not bother u again.
1helpful
2answers
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
