SOURCE: 3D Architect and 3D Landscaper are not running with Windows Vista...
if your problem is the installation in Windows Vista--> Try to use this sw in Compatibility mode--> Desktop--> right click on the program icon--> Properties--> compatibility--> select Windows XP or other older version
SOURCE: I recently downloaded
How much ram memory does your computer have? Go to "Control Panel" > "System" and on that first page you see, look under computer and it will say how fast your computer is and how much memory you have. See if your software lists any kind of system requirements to run the software. Programs like that can use a lot of memory when you're creating drawings like that. Your operating system also requires a certain amount of memory to run. IT and the software are probably exceeding what you have in your system.
SOURCE: how to use 3D Home
You-Tube video "uxVSgvJpLq0" placeholder Follow this video tuto..
collect the reference images and keep on practice .. ; )
SOURCE: Can I make a older version of 3D home Architect ,,
no because drivers is in every windows some will work and some want.
SOURCE: 3D Home Architect Design Suite
Try reinstall, or repair, if not download or install it again using your cd/ or dvd installer.
