Televison & Video Logo
Posted on Jan 18, 2018
Purchased a Zenith TV (model #Z20LCD1 Serial #609TPAE12392} the directions nor a remote was in the package. I am unable to change channels and it is on Channel 11 an ETV channel. When I go to the menue, manualy everything seems to be in spanish and I am unable to change to English. Please advise
hhguzman
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 18, 2018
hhguzman
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9011
Points
14
For changing language you need to go to the Special Menu Options. While on the menu select the one on the far right (past audio, picture menu options). Second line in special menu is the one to select Language, you can change it to english there.
https://www.manualslib.com/manual/376266/Zenith-Z15lcd1-15-Lcd-Hdtv.html?page=19#manual
  • Anonymous Jan 18, 2018
    Wrong answer
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Feb 08, 2008
SOURCE: TV (RCA model F32705) stuck on one channel
go to setup in menu from fromt of set. do 1st time setup ...tell it you do NOT have a cable box. if it thinks you have one it deletes all channels but 3.
Anonymous
  • 110 Answers
  • Posted on Feb 17, 2008
SOURCE: Picture gone from TV Model LE46M51B
I suspect that your backlight has gone out. If you shine a light on the screen can you see remnants of the picture that should be displaying? If so, it's definitely the backlight, and most likely the power inverter for the backlight. You can probably find a replacement inverter, but you may need a repair manual to install it. I'd recommend checking the warranty status first and sending it in for repair if you can.
Anonymous
  • Posted on May 21, 2008
SOURCE: Auto SAP
The problem is not a cable one, but a TV function. Pull out your user manual for your TV. My dad just had this happen, and he has a Sony WEGA TV. The auto sap is an AUTO Secondary Audio Program, you need to find the menu to back out of it.
Good luck.
Anonymous
  • Posted on May 25, 2008
SOURCE: Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
A
Anonymous
  • Posted on Sep 12, 2008
SOURCE: JVC tv model HD56G786
this isn't solution
Fix philips rc 144 a/v button for zenith z20lcd1
There is no such key fix. Just try an other code to set-up with your remote control. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Z20lcd1
I connected a vga cable into my unit and my netbook but it's also saying "no suport".
help, I'll like to use my unit with my z20lcd1 tv/monitor unit.
Remote stopped working!
To turn off the 100 button you need the original remote.
Order a replacement from one of the sellers below:
Used Original Zenith Z20LCD1 Remote Control
Zenith Z20LCD1 Replacement Remote
Regards
Change to channel 3 rather than 2 on Zenith 27" withot a remote
You can use the menu button on the front to autoprogram the unit. Make sure the direct tv is on so the tuner will pick it up. After that, you can program the direct tv remote to operate the tv. The reason the channels won't change is there are none in the memory
2helpful
2answers
Flat screen zenith Z20LCD1 use as a moniter HOW? Thanks
this is from the manual:
When the input source is PC (Only for Z15LCD1)...
PC S ettup ((Z151L5CLC1RD1
onlly))
Connections
1. Set the monitor output resolution on the PC before connecting to the TV.
2. Connect the TV to the PC with the PC cable.
3. Connect the PC audio output to the TV's PC S OUND input.
Viewing Setup
1. Turn on the PC.
2. Use the PC b utton on the remote control to select PC .
it appears only the 15" model may be used as pc monitor
1helpful
2answers
Zenith zn620 universal remote
This may be of help for Zenith codes:
http://www.thompsontv.com/zcodes.html
2answers
Did you ever fix your zenith LCD z20lcd1 ?
same problem, after hitting power button hit channel up or down and it comes on
2answers
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
