My lens won't go back into the camera. Everytime I turn on the camera a green light flashes several times and then on the bottom right of the screen it says "lens error, will shut down automatically, redraft camera". Please help this is SO frustrating!
hello,are you sure that you have not left your camera flash on,and virtually killed off the battery?as the zig zag icon usually refers to mostly flash related aspects of most modern cameras,all cameras need a certain base level battery power,before they will switch on for use,but may well display all manner of icon's and oddity's when the power is all consumed.hope that helps, cheers.
I had the same thing happen to me with my pentax optio. You may have to large of an SD memory card. Or you could have the wrong type of card. I would recomemd that you use a 512mb SD card. Not the SDHC card. Also i would make sure that the battaries are fully charged. Hope this helps you out!
My Samsung camera SL105 won't turn on. When I push the power button the lens tries to extend out but won't. Then it beeps and goes back in. What is this from. I got it to open a couple times today but back to same now.
Sorry about your moms camera Terry... but it sounds like it needs the lens replaced. If the lens is stuck out at an angle you can *SNAP* the inner lens section back into place if you're lucky, and it will work again like normal.
I don't know your model, but a refurb lens can usually be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why green light blinking continues. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at [email protected]
