20 Most Recent Kodak EasyShare C653 Digital Camera Questions & Answers
If the camera saves to a memory card try plugging that into your pc instead of going through the camera.
Kodak EasyShare... | Answered on Jul 12, 2015
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Kodak EasyShare... | Answered on May 01, 2014
Kodak EasyShare... | Answered on Mar 12, 2014
Can you remove the card, and put it into a PC or laptop with a reader or do you have a reader so you don't loser what's on the card ?
If the card freezes the camera, you need to plug this card into a PC and do a quick format.
Then try it in camera, if it doesn't freeze the camera you need to format the card with the camera.
Remember, the manual say's only 1g cards max, most non SDHC are 2g, but the manual say's only 1g.
So if the card is bigger then 1g, this can be the problem.
Kodak EasyShare... | Answered on Apr 15, 2013
What type and size memory card? The C653 works with MMC and SD cards, 2GB or smaller. Even though SDHC cards will fit into the slot, they are electronically incompatible and will not work with this camera.
What type and size memory card? The C653 works with MMC and SD cards, 2GB or smaller. Even though SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Change the color mode to "Black & White". See this page of the user guide.
You might want to consider taking color photos and waiting to convert to black & white until you get them on a computer. Converting on a computer gives you much more control over factors such as contrast and luminescence.
Kodak EasyShare... | Answered on Jan 17, 2013
The date and time (and a lot more) are automatically stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Kodak EasyShare... | Answered on Dec 27, 2012
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
The camera is having problems focusing. Try focusing on a bright object hold the shutter button half way down to lock the focus then frame your image and press the shutter to take the photo.
If this does not work then try manual focus.
Kodak EasyShare... | Answered on Dec 12, 2012
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Kodak EasyShare... | Answered on Aug 12, 2012
One source for the LCD screen is here.
Kodak EasyShare... | Answered on Apr 04, 2012
Kodak EasyShare C653 Digital Camera Logo
96 questions posted
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
pc still shows camera as live device but
  • Cameras
